Grafana Cloud Metrics Endpoint error for WordPress plugin
I’ve added a REST API plugin in WordPress that returns data in Prometheus format (wp_posts_total{status=“draft”} 0) at the link: /wp-json/metrics, without authentication. This works from the browser.
I’ve tried to connect using a Metric Endpoint from Grafana Cloud, but I have the error: The request to the provided endpoint did not return a valid response. Please ensure your URL is correctly setup to handle authentication credentials.
In section: Enter the URL to scrape, and the necessary Auth Credentials, I’ve added some mandatory random user/password and the link: /wp-json/metrics.
Could you please specify which is the reason of the error ?
Thank you,
Mihai
Did you solve this issue?
I have a similar problem with Metrics Endpoint.
I have a public /metrics endpoint serving well-formed Prometheus metrics (that I can scrape with Prometheus) but, like you, when I try to configure Metrics Endpoint with the URL and with arbitrary “Bearer Token” (which should work since the /metrics endpoint will respond with|without the header), I get the same error.
There appears to be no way to debug this configuration either. It would be helpful if the service presented request|response messages for debugging.
I’m able to make the request using curl directly and it returns a 200 and well-formed Prometheus text-based exposition format content.
I have the totally same issue with Metric Endpoint, too.
Bumping for continued visibility. I am having the same issue when authenticating with a bearer token using the Metrics Endpoint. I can also exactly the same url and token in Postman and I can access the metrics successfully.
I am using a long token (72 chars IIRC) so I wonder if there is not some truncation taking place…
As an update, I tried with a significantly shorter token and that made no difference.
To close the loop on this case for my particular problem:
It turns out that, even when using Bearer auth, the Metrics Endpoint HTTP makes the initial request without any Authorization header. Only once the the host responds with a 401 will Metrics Endpoint make a second request that includes the Authorization header.
I initially diagnosed this using webhook.site and I was able to change the behaviour of our application to respond with a 401 when the Bearer token was absent and that resolved the issue in our case.
Wow, that’s insane behaviour.
I lost so much time on this. I could see my the http logs coming through from grafana, and my server responding 200 OK. I never would have guessed that it would have tested your authentication before allowing you to create a job. I was just about to give up before finding this thread.
If anyone wants to bypass it, I added this middleware at the top of my app (nodejs/express):
app.use((req, res, next) => {
  if (req.headers['user-agent'] === 'grafanacloud' && !req.headers.authorization) {
    res.header('WWW-Authenticate', 'Basic');
    res.status(401).send();
  } else {
    next();
Per the Metrics Endpoint docs, you must provide authentication details: “Note that it is mandatory to provide authentication details, and Grafana Cloud won’t accept a public URL that is not protected by authentication”.
