Say I have an endpoint on my host that returns metrics in JSON format, something like
$curl localhost:8080
"key": value
How could I get these metrics into Grafana?
"key": value
You maybe can use the Simple JSON Datasource plugin. You need to tweak your endpoint so that it returns data in a format that the Simple JSON Datasource understands.
Marcus
