I’m creating a dashboard pane where I want to display a query in a timeseries chart. This works fine but the problem is that it doesn’t display enough data, so I increased the “line limit” of my query to the max, which is currently 5000. I’d like to display more lines though but I can’t set it to a value higher than 5000.
In self-hosted grafana systems, I think there is the possibility to change the “max_entries_limit” configuration.
Is this also possible with the grafana cloud system? Where can I change this limit?
Thanks!
