Grafana Cloud access to config.ini variables
Hi there,
Is there posibility to tweak config.ini varibales in some way when using Grafana Cloud?
Mainly I would like to set disable_sanitize_html = true
Thank you :slight_smile:
That can be very dangerous feature in the Grafana Cloud. I bet it won’t be allowed, because security.
