Grafana-cli not found
#1
How do you install the grafana-cli? It doesn’t state it anywhere in the docs. Whenever I try a command like grafana-cli plugins list-remote it jsut says grafana-cli is not recognized as an internal or external command.
#2
if you install grafana via deb & rpm package it should be installed to a bin directory that is in your path. If you installed by downloading a binary zip/tar package, it should be in the bin directory
