Grafana V9.0.3 OSS -
I am trying to restrict grafana users to only access the grafana login page thru reverse proxy (NGINX). I have a grafana instance running on port 3000 behind the nginx reverse proxy on the same local machine.
reverse proxy works well, however I can still access the grafana thru http://localhost:3000, what I want is no once can access this web page, I want all grafana user to access the grafana thru nginx reverse proxy. -
I haven’t yet seen any blogs or tutorials on how to restric the users. -
What happened?
I can still access the grafana thru http://localhost:3000 -
Grafana instance can only be access thru my nginx reverse proxy. -
This is my config on nginx:
No errors -
I haven’t seen any blog related to this.
I don’t think what you want is entirely possible using a proxy_pass
. If you are proxying to local port 3000 then that port by definition must be open locally.
Are you running a server? Or is this a closed network? Access to localhost shouldn’t be a problem if you are running Grafana on a VM or cluster and access to the vm / cluster is locked down
also, these are the types of config issues that are entirely eliminated when one uses Grafan cloud. You should set up a free-forever account and see if it makes setup easier:
My Nginx and Grafana instance is running on same machine.
Will it be possible to close the port 3000 for non localhost (any client computers connected to a network) accessing the grafana?
And just open port for nginx which is port 443.
From there, they cannot access my grafana using the http://ipaddressofmyGrafana:3000
I just dont know if possible.
