Our Grafana alert policy is configured as can be seen below. I have two questions:
I may be misunderstanding something but it keeps firing twice to Microsoft Teams. Any help will be greatly appreciated.
I need help with timing logic. What I want is an alert firing once conditions are met and to repeat every 12 hours. If conditions change I want a new alert firing.
Thank you for any help extended,
-Shai
Any help? I know grafanacon was going on last week - if anyone freed up I would greatly appreciate assistance.
Hi!
Are you running Grafana with high availability? If so, have you followed the instructions here?
We are using Azure Managed Grafana. From an initial search there doesn’t seem to be a way to edit the availability in Azure Managed Grafana and I’m unaware of a way to edit config files
Thanks for your help!
Maybe, though I am in Azure not AWS. If it’s a bug is there a support ticket open for it?
I would ask support if you can because it looks like a case of duplicate notifications due to incorrect HA configuration.
