Grafana alerting with ms office teams
I have configured a Grafana setup on my local machine. I also installed Prometheus on the same VM, and set up Node Exporter on a target VM to collect metrics for creating visualizations in Grafana.
Currently, I’m stuck at configuring alerts for the target VMs to monitor CPU and RAM usage. I tried using Prometheus Alertmanager along with a Python script to send alerts to a Microsoft Teams webhook, but the alerts are not reaching Teams.
Does anyone have any ideas on how to resolve this issue? Alternatively, I’d appreciate suggestions for configuring alerting—either using a Python script or any other effective method.
Thanks in advance!
Why using python script when Grafana has built-in alerting feature with designated MS Teams contact point?
@dawiddebowski
It looks like webhook connection to MS Teams (which is being used by the solution you mentioned?) is being deprecated. Probably the only way to do it now is to create a custom connector for Power Automate
