I’m using the Grafana Agent Operator, installed via helm chart (chart version 0.2.8).
I successfully created a GrafanaAgent via CRD. It is using the image grafana/agent:v0.30.2 as given in the example in the documentation.
Now I’m trying to create an agent with an Integration CRD.
Here is my CRD
apiVersion: monitoring.grafana.com/v1alpha1
kind: Integration
metadata:
namespace: grafana-agent-operator
labels:
agent: grafana-agent-integrations
spec:
type:
unique: true
allNodes: false
config:
instance: "app-agent-receiver"
server:
cors_allowed_origins:
- http://grafana.staged-by-discourse.com
rate_limiting:
enabled: true
This indeed creates an integration deployment. This is the configuration that is created by the operator:
/ # cat /var/lib/grafana-agent/config/agent.yml
integrations:
agent_configs:
- instance: app-agent-receiver
server:
rate_limiting:
enabled: true
metrics:
autoscrape:
enable: false
logs:
positions_directory: /var/lib/grafana-agent/data
metrics:
global:
external_labels:
cluster: grafana-agent-operator/grafana-agent
wal_directory: /var/lib/grafana-agent/data
server:
log_level: info
But the agent won’t start, all it says is the error message
2023/01/18 09:48:47 error loading config file /var/lib/grafana-agent/config/agent.yml: yaml: unmarshal errors:
line 2: field server not found in type agent.Config
What puzzles me is line 2 of the agent.yml (“agent_configs”). My understanding is that the operator is already using integrations-next, so according to this documentation line 2 should be “agent:”
Or is there anything I did wrong in the Integrations CRD?
