Kubernetes 1.24, Grafana cloud latest?
I am trying to setup agent-operator on kubernetes -
Following agent-operator setup instructions provided in Grafana kubernetes setup dashboard. -
What happened?
grafana-agent-integrations-dsis in CrashLoopBackoff state. Getting following error in the logs
│ name │
│ grafana-agent ts=2023-02-07T09:39:39.294860434Z caller=node_exporter.go:60 level=info component=integrations integration=node_exporter instance=server:8080 collector=v ││ mstat │
│ grafana-agent ts=2023-02-07T09:39:39.294883167Z caller=node_exporter.go:60 level=info component=integrations integration=node_exporter instance=server:8080 collector=x ││ fs │
│ grafana-agent ts=2023-02-07T09:39:39.294899808Z caller=node_exporter.go:60 level=info component=integrations integration=node_exporter instance=server:8080 collector=z ││ fs │
│ grafana-agent ts=2023-02-07T09:39:39.295628949Z caller=autoscrape.go:127 level=error component=autoscraper msg="cannot autoscrape integration" name=node_exporter/serve ││ r:8080 err="instance default/grafana-agent-metrics does not exist" │
│ grafana-agent ts=2023-02-07T09:39:39.295673241Z caller=main.go:57 level=error msg="error creating the agent server entrypoint" err="configuring autoscraper failed: ins ││ tance default/grafana-agent-metrics does not exist" │
│ Stream closed EOF for default/grafana-agent-integrations-ds-klsh8 (grafana-agent) ││ config-reloader level=error ts=2023-02-07T09:40:42.209297894Z caller=runutil.go:101 msg="function failed. Retrying in next tick" err="trigger reload: reload request fa │
│ iled: Post \"http://127.0.0.1:8080/-/reload\": dial tcp 127.0.0.1:8080: connect: connection refused" ││ config-reloader level=error ts=2023-02-07T09:40:47.209495937Z caller=runutil.go:101 msg="function failed. Retrying in next tick" err="trigger reload: reload request fa │
│ iled: Post \"http://127.0.0.1:8080/-/reload\": dial tcp 127.0.0.1:8080: connect: connection refused" ││ config-reloader level=error ts=2023-02-07T09:40:52.206259881Z caller=runutil.go:101 msg="function failed. Retrying in next tick" err="trigger reload: reload request fa │
│ iled: Post \"http://127.0.0.1:8080/-/reload\": dial tcp 127.0.0.1:8080: connect: connection refused" ││ config-reloader level=error ts=2023-02-07T09:40:57.207740553Z caller=runutil.go:101 msg="function failed. Retrying in next tick" err="trigger reload: reload request fa │
Agent operator installed successfully and I should have been able to view it in kubernetes dashboard. -
No data on dashboards -
Grafana
