Grafana Agent Operator not sending logs
I have 2 EKS clusters. One running Loki installed via helm and the agent operator installed via that helm chart. One where I am trying to deploy using the Agent Operator Helm chart.
The Loki cluster is sending logs to Loki. The other one is not. Here are my grafanaagent, logsinstance and podlogs CRs…
apiVersion: monitoring.grafana.com/v1alpha1
kind: PodLogs
metadata:
  labels:
    instance: primary
    app.kubernetes.io/instance: gel-prod
    app.kubernetes.io/name: enterprise-logs
  namespace: monitoring
spec:
  namespaceSelector:
    any: true
  pipelineStages:
  - cri: {}
  relabelings:
  - action: replace
    sourceLabels:
    - __meta_kubernetes_pod_node_name
    targetLabel: worker_node
  - action: labelmap
    regex: __meta_kubernetes_pod_label_(.+)
  - action: replace
    replacement: grafana-ent/$1
    sourceLabels:
    - __meta_kubernetes_pod_controller_name
    targetLabel: job
  - action: replace
    sourceLabels:
    - __meta_kubernetes_pod_container_name
    targetLabel: container
  - action: replace
    replacement: eks01-uinfra
    targetLabel: cluster
  - action: replace
    sourceLabels:
    - app_kubernetes_io_managed_by
    targetLabel: managed
  - action: replace
    sourceLabels:
    - app_kubernetes_io_name
    targetLabel: cloudapp
  - action: drop
    sourceLabels:
    - operator_agent_grafana_com_name
    - operator_agent_grafana_com_type
    regex: (.*)
  selector:
    matchLabels: {}
 kind: LogsInstance
 metadata:
   annotations:
     meta.helm.sh/release-name: gel-prod
     meta.helm.sh/release-namespace: monitoring
   labels:
     agent: grafana-agent
 spec:
   clients:
   - url: http://logs.atops.ue1.redacted.com/loki/api/v1/push
     externalLabels:
       cluster: uinfra01
     basicAuth:
       username:
         key: username
       password:
         key: password
   podLogsNamespaceSelector: {}
   podLogsSelector:
     matchLabels:
       instance: primary
kind: GrafanaAgent
metadata:
  annotations:
  labels:
spec:
  serviceAccountName: grafana-operator-grafana-agent-operator
  logs:
    instanceSelector:
      matchLabels:
Anyone have any idea what is going on here?
