How can I send log line to differt locations?
  • Grafana agent (config.river), setup with Grafana Cloud,
Installed to GKE Kuberntes cluster.
  • I want to filter a log line (“level”:“ACTIVITY”) and send to a different out than the LOKI endpoint in Grafana cloudn
Trying to figure it out from online instructions : loki.process | Grafana Agent documentation but am kind of lost.
Can not find a good example on how to do this.
Example log:
{“level”:“ACTIVITY”, “message”: “various stuff”} (a log line i do not wan to send to Loki)
{"level:“INFO”, “ip”: “1.2.2.3”, “http”:“GET /”} … (all other go to Loki endpoint in Grafana cloud.
Default config:
discovery.kubernetes "pods" {
  role = "pod"
// Pod
    Logs
discovery.relabel "pod_logs" {
  targets = discovery.kubernetes.pods.targets
    \ rule {
    source_labels = ["__meta_kubernetes_namespace"]
    action =
    "replace"
    target_label = "namespace"
  rule {
    source_labels
    = ["__meta_kubernetes_pod_name"]
    action = "replace"
    target_label
    = "pod"
  rule {
    source_labels = ["__meta_kubernetes_pod_container_name"]
    \   action = "replace"
    target_label = "container"
  rule {
    source_labels
    = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name"]
    separator
    action = "replace"
    replacement = "$1"
    target_label
    = "job"
  rule {
    source_labels = ["__meta_kubernetes_pod_node_name"]
    \   action = "keep"
    regex = env("HOSTNAME")
  rule {
    source_labels
    = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
    \   separator = "/"
    action = "replace"
    replacement = "/var/log/pods/*$1/*.log"
    \   target_label = "__path__"
local.file_match "pod_logs" {
  path_targets
    = discovery.relabel.pod_logs.output
loki.source.file "pod_logs" {
  targets
    \   = local.file_match.pod_logs.targets
  forward_to = [loki.process.pod_logs.receiver]
loki.process
    "pod_logs" {
  stage.docker {}
  forward_to = [loki.write.grafana_cloud_loki.receiver]
// Grafana Cloud Loki
local.file "loki_host" {
  filename  = "/etc/grafana-agent-credentials/loki_host"
local.file
    "loki_username" {
  filename  = "/etc/grafana-agent-credentials/loki_username"
local.file
    "loki_password" {
  filename  = "/etc/grafana-agent-credentials/loki_password"
    \ is_secret = true
loki.write "grafana_cloud_loki" {
  endpoint {
    url
    = nonsensitive(local.file.loki_host.content) + "/loki/api/v1/push"
    basic_auth
      username = local.file.loki_username.content
      password = local.file.loki_password.content
  external_labels = {
    cluster = "keystrike-development",
