I use this tutorial to setup agent on my docker-compose
This project was blue print for my config:
I only care for the logs so after setup loking in grafana cloud my config looks like this:
Agent:
server:
log_level: debug
logs:
configs:
- name: default
positions:
filename: /tmp/positions.yaml
scrape_configs:
- job_name: jobname
static_configs:
- targets: [localhost]
labels:
job: jobname
__path__: /logs/*log
clients:
- url: https://logs-prod-017.grafana.net/loki/api/v1/push
basic_auth:
username: <username>
password: <pass>
target_config:
sync_period: 10s
And docker compose
agent:
image: grafana/agent:latest
volumes:
- ./agent.yaml:/etc/agent-config/agent.yaml
- logs:/logs:ro
- /tmp/agent:/etc/agent
entrypoint:
- /bin/agent
- -config.file=/etc/agent-config/agent.yaml
- -enable-features=integrations-next
- -config.expand-env
- -config.enable-read-api
environment:
HOSTNAME: agent
ports:
- "127.0.0.1:4317:4317"
volumes:
logs:
Run everything, image is working ok, but then nothing is send to cloud.
Logs for agent this looks like this:
