Grafana 8.0.6, deployed via Kubernetes via the official Helm chart -
Trying to make websockets work. -
Websockets to work. -
image:
repository: grafana/grafana
tag: 8.0.6
pullPolicy: IfNotPresent
replicas: 1
podDisruptionBudget:
minAvailable: 1
autoscaling:
enabled: true
minReplicas: 1
maxReplicas: 10
metrics:
- type: Resource
resource:
targetAverageUtilization: 60
namespaceOverride: monitoring
rbac:
create: true
pspEnabled: false
serviceAccount:
create: true
ingress:
enabled: true
hosts: [ "subdomain.domain.tld", "subdomain.domain.tld_1" ]
annotations:
kubernetes.io/ingress.class: "nginx-internal"
nginx.org/websocket-services: "grafana"
nginx.ingress.kubernetes.io/proxy-read-timeout: "3600"
nginx.ingress.kubernetes.io/proxy-send-timeout: "3600"
resources:
limits:
cpu: 100m
memory: 128Mi
requests:
cpu: 100m
memory: 128Mi
imageRenderer:
enabled: true
grafana.ini:
server:
domain: subdomain.domain.tld
root_url: "%(protocol)ss://%(domain)s/"
live:
allowed_origins: *
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
wss://subdomain.domain.tld/api/live/ws→ status 400
disconnected: connection closed true [centrifuge.js:2899:13](webpack:///node_modules/centrifuge/dist/centrifuge.js)
Status connecting -> disconnected [centrifuge.js:2899:13](webpack:///node_modules/centrifuge/dist/centrifuge.js)
reconnect after 1281 milliseconds [centrifuge.js:2899:13](webpack:///node_modules/centrifuge/dist/centrifuge.js)
start connecting [centrifuge.js:2899:13](webpack:///node_modules/centrifuge/dist/centrifuge.js)
Status disconnected -> connecting
- Did you follow any online instructions? If so, what is the URL?
helm-charts/charts/grafana at main · grafana/helm-charts · GitHub
Hello everyone.
I’m trying to make websockets work with Grafana, but the request always fails with 400. I tried allowing all domains as there are several bug tickets open, but still no success. In the Grafana logs I see
t=2021-07-23T07:22:52+0000 lvl=info msg="Request Completed" logger=context userId=95 orgId=1 uname=<user> method=GET path=/api/live/ws status=400 remote_addr=<IP> time_ms=10 size=12 referer=
Does anyone have any ideas?
