my influx is collecting metrics
grafana reads metrics but doesn’t display them as a graph
how can i solve this
Try to display graph by point. On your server, can you see if you have correct timestamp.
Thanks,
any suggestions for this problem???
Do you get some useful output of the db query? Any data in ‘inspect -> data’ ?
On my own pc it’s working good and it’s showing the graphs
but in some computers while openning the dashboard it’s just show the legend without any graph
Do you use the same browser ans version on all computer ?
Yes google chrome last update
The only thing I can see about this problem, you don’t have de same configuration on grafana servers. Do some check.
I am using one server
I just access from a different device and with the same version of chrome browser but i got that problem of graph not showing
Ok, which devices do you use ?
You can try something on all devices :
And timestamp of all devices are the same ? It’s very important to check this.
