Grafana 7.5 with Tempo
7.5 / linux
I am trying to add Tempo as a data source to Grafana.
  • What happened?
Everything’s ok when adding tempo as a data source (http://tempo-tempo-distributed-query-frontend.monitoring:16686) to Grafana until version 7.4.5 .
Starting from 7.5 grafana image I’m getting the following error:
“failed to convert tempo response to Otlp: proto: ExportTraceServiceRequest: wiretype end group for non-group”
I understand that accordingly to 7.5 release notes (https://grafana.com/docs/grafana/latest/whatsnew/whats-new-in-v7-5/#tempo-as-a-backend-data-source) the support for tempo-query’s (Jaeger) response was dropped, I’m pretty sure that’s related to it, but I’m not sure what am I supposed to do to move forward with this.
I would expect to add Tempo as a data source successfully
grafana t=2021-06-05T16:26:14+0000 lvl=eror msg="Metric request error" logger=context userId=1 orgId=1 uname=admin error="failed to convert tempo response to Otlp: proto: ExportTraceServiceRequest: wiretype end group for non-group" remote_addr=10.123.33.253**
Hi @mfamador
Tempo 1.o just shipped along with Grafana 8 this week. Have you considered upgrading? That might solve this installation issue…
Hi! Thanks, @mattabrams ! My bad, I should have updated this thread, I solved it using the opentelemetry port instead of the Jaeger one.
http://tempo-tempo-distributed-query-frontend.monitoring:3100
