Sending Jaeger traces to Tempo
I am trying to set up a jaeger data source for grafana tempo. So I set the HTTP url to “http://node0.raft.collaborate.emulab.net:16686”, which is the hostname that run the jeager using docker (docker run -d -p 16686:16686 -p 6831:6831/udp jaegertracing/all-in-one) and the port of jaeger. I send traces running a python script (jaeger_exporter = JaegerExporter(
agent_host_name=“localhost”,
agent_port=6831,…).
However, I get query error and I do not see any traces in tempo.
Thank you in advance,
Andria
Hi @antrigeorgi. I’m sorry, but I don’t think I understand the problem. Where is Tempo in this setup? Or are you using only Jaeger and Grafana?
Yes I am using the online Grafana Tempo, and in the URL field of data source I set the hostname and port of Jaeger as shown in the attached picture.
If your backend is Jaeger, you should be using the Jaeger datasource.
Oops! I see… I thought that tempo data source was compatible with jaeger.
Thank you very much for your reply!
Andria
