Grafana 5: Possible bugs
First of all, congratulations for the new release, it’s awesome and promising.
I’ve tested it (Debian / Chrome) and 2 issues faced (Both worked on earlier versions):
  • Impossible to create template variables.
  • Piecharts: position legend to the right side is not working
Regards,
Are you trying to see template variables for a new or existing dashboard? Any errors in chrome dev tools in console tab? Regarding pie chart are you using latest version?
Marcus
  • I created a new dashboard and found no way to add template variables (under dashboard settings as usual or anywhere else).
  • I upgraded the pie chart plugin and that works (legend on the right) - my bad.
    Thanks
Template variables in dashboard settings are now titled Variables, see screenshot below.
Marcus
Hi Marcus
I have the same problem to add new Variables to a new Dashboard when is use Chrome Version 64.0.3282.186 (os/X) - It works with Firefox.
thnx
Please include more information. Do you get any error messages? If you open the chrome dev tools you see any errors logged in the console tab? In network tab are there any bad request?
Marcus
Hi Marcus
I have now migrated to the latest/stable version 5.0.0. and it works now fine with Chrome, Firefox and Safari.
thnx
Thanks Marcus, it was right under my nose :stuck_out_tongue:
I’ve seen that you’ve added sorting to stacked graphs – awesome addition, thanks and keep it up team
