Hi All!
I attached google sheet to Grafana using the pug-in.
I encountered a problem, the format in the time column is displayed as automatic and not as “TIME”
Hi All!
Welcome
Which plugin are you using to connect to the google sheet? Please post a sample data for the time column
can you use transformation to convert it to the data type you want it to be? I dont know if there is a time data type, you might need to do some calculations. because right now it looks like it is treating 11:19:00 as some sort of ratio calculation
11:19:00 is not a real data type of any sort within grafana I do not think
You changed it in google sheets but grafana does not have time data type. and what is the end goal with this data? visualize it in a time series? bar graph?
Yes.
Visualize it in a time series, bar graph.
