Even though the first column of the google sheet shows the dates in all rows, when I query the data in Grafana to create the dashboard, the table-like dash in Grafana does not show all the data.
Here are prints for verification.
Can you help me?
Google Sheet
missing data in Grafana table
I was able to solve it by changing the date type to MM-DD-YYYY in the Google Sheet date column.
The question remains, how to adjust grafana to accept the Brazilian format DD-MM-YYYY of data sources like google sheet, considering that I have a connection to a mysql database and in this format works very well?
Can you use convert transformation?
I already used it, but if I don’t configure the date in the google sheet column MM-DD-YYYY it doesn’t work, that’s what I wanted to avoid. But thanks!
Facing same probelm in my googlesheet hava data in purchase field but not showing in grafana. i have done all the way to change datatype using convert type transformation.
