Dashboard date format change 2024-01-12 04:06:02.000 to 01/12/2024 04:06:02
Hello
I am reading data from google sheets and the date/time format there is in the correct time zone and shows the time formated the way I expect ie 14/02/2024 21:40:54 but when this is viewed in grafana in swaps the date around, how is this controlled?
Did you ever get a solution? The recommendation below doesn’t work for the free version as you can’t edit the config files.
