Working in Grafana main branch at this commit fef490e
Working from Windows, building Docker container.
- What are you trying to achieve?
We are trying to automate building and pushing a container image to Amazon ECR. Then we would like to deploy the application using AWS ECS.
- How are you trying to achieve it?
1.Mirrored the official Grafana repository
2.Removed “.git” from .dockerignore
3.Tested building locally with no problems: docker build -t grafana-app .
4.Setup the Github Action: Amazon ECS “Deploy Task Definition” Action.
5. Started the workflow and it failed with the following error:
Step 47/67 : COPY ${GRAFANA_TGZ} /tmp/grafana.tar.gz
COPY failed: file not found in build context or excluded by .dockerignore: stat grafana-latest.linux-x64-musl.tar.gz: file does not exist
Error: Process completed with exit code 1.
6.I also tried to remove “/tmp” from .dockerignore but I still received the error.
We expected the docker container to build, push, and then deploy to ECS because it works when we attempted this manually (without the Github Action).
Why would the file be found when we run build locally but not through the Github Action?
Are there any suggestions on what to do or how to further debug this issue?
Thanks!
