Grafana docker build failed - Couldn't find any versions for "@grafana/data" that matches "workspace:*"
Hi Team,
I have downloaded Grafana from GitHub and trying to do docker build but it is failing with below error stack. Please let me know if I am missing something here.
=> CANCELED [go-builder 12/12] RUN go run build.go build        35.8s
 => ERROR [js-builder  6/12] RUN yarn install --pure-lockfile --no-progress        35.1s
 > [js-builder  6/12] RUN yarn install --pure-lockfile --no-progress:
#32 0.626 yarn install v1.22.15
#32 0.808 [1/5] Validating package.json...
#32 0.823 [2/5] Resolving packages...
#32 34.40 error Couldn't find any versions for "@grafana/data" that matches "workspace:*"
#32 34.40 info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
executor failed running [/bin/sh -c yarn install --pure-lockfile --no-progress]: exit code: 1
Thanks in advance.
@sharathramprasad if you are still encountering this, please post more details about version info and OS. Thanks :+1:
Even I am getting same issue error Couldn't find any versions for "@grafana/data" that matches "workspace:*"
trying docker Build for custom image from Mac M1(Mac OS monterey)
@anon70503803, @jayarajesvar I am using Windows 10 and Grafana 8.2.2 and this issue got resolved by replacing the docker file in the installation directory with the below docker file.
Thanks.
I am getting yarn build error
docker build --build-arg "GRAFANA_VERSION=latest" --platform linux/amd64  -t custom -f Dockerfile .
[+] Building 1003.6s (41/45)
 => [internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 120B        0.0s
 => [internal] load .dockerignore        0.0s
 => => transferring context: 118B        0.0s
 => [internal] load metadata for docker.io/library/alpine:3.14.3        1.1s
 => [internal] load metadata for docker.io/library/node:16-alpine3.14        1.1s
 => [internal] load metadata for docker.io/library/golang:1.17.3-alpine3.14        1.1s
 => [internal] load build context        0.6s
 => => transferring context: 1.63MB        0.6s
 => [go-builder  1/13] FROM docker.io/library/golang:1.17.3-alpine3.14@sha256:55da409cc0fe11df63a7d6962fbefd1321fedc305d9969da636876893e289e2d                                                         0.0s
 => [js-builder  1/13] FROM docker.io/library/node:16-alpine3.14@sha256:60ef0bed1dc2ec835cfe3c4226d074fdfaba571fd619c280474cc04e93f0ec5b                                                               0.0s
 => [stage-2  1/13] FROM docker.io/library/alpine:3.14.3@sha256:635f0aa53d99017b38d1a0aa5b2082f7812b03e3cdb299103fe77b5c8a07f1d2        0.0s
 => CACHED [stage-2  2/13] WORKDIR /usr/share/grafana        0.0s
 => CACHED [stage-2  3/13] RUN apk add --no-cache ca-certificates bash tzdata musl-utils        0.0s
 => CACHED [stage-2  4/13] RUN apk add --no-cache openssl ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main                                               0.0s
 => CACHED [stage-2  5/13] RUN apk upgrade ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main                                                              0.0s
 => CACHED [stage-2  6/13] RUN apk info -vv | sort        0.0s
 => CACHED [stage-2  7/13] COPY conf ./conf        0.0s
 => CACHED [stage-2  8/13] RUN if [ ! $(getent group "0") ]; then   addgroup -S -g 0 grafana;   fi        0.0s
 => CACHED [stage-2  9/13] RUN export GF_GID_NAME=$(getent group 0 | cut -d':' -f1) &&   mkdir -p "/usr/share/grafana/.aws" &&   adduser -S -u 472 -G "$GF_GID_NAME" grafana &&   mkdir -p "/etc/graf  0.0s
 => CACHED [js-builder  2/13] WORKDIR /grafana        0.0s
 => CACHED [js-builder  3/13] COPY package.json yarn.lock .yarnrc.yml ./        0.0s
 => CACHED [js-builder  4/13] COPY .yarn .yarn        0.0s
 => CACHED [js-builder  5/13] COPY packages packages        0.0s
 => CACHED [js-builder  6/13] COPY plugins-bundled plugins-bundled        0.0s
 => CACHED [js-builder  7/13] RUN yarn install        0.0s
 => CACHED [js-builder  8/13] COPY tsconfig.json .eslintrc .editorconfig .browserslistrc .prettierrc.js babel.config.json ./        0.0s
 => CACHED [go-builder  2/13] RUN apk add --no-cache gcc g++ make        0.0s
 => CACHED [go-builder  3/13] WORKDIR /grafana        0.0s
 => CACHED [go-builder  4/13] COPY go.mod go.sum embed.go Makefile build.go package.json ./        0.0s
 => CACHED [go-builder  5/13] COPY cue cue        0.0s
 => CACHED [go-builder  6/13] COPY packages/grafana-schema packages/grafana-schema        0.0s
 => CACHED [go-builder  7/13] COPY public/app/plugins public/app/plugins        0.0s
 => CACHED [go-builder  8/13] COPY pkg pkg        0.0s
 => CACHED [go-builder  9/13] COPY scripts scripts        0.0s
 => CACHED [go-builder 10/13] COPY cue.mod cue.mod        0.0s
 => CACHED [go-builder 11/13] COPY .bingo .bingo        0.0s
 => CACHED [go-builder 12/13] RUN go mod verify        0.0s
 => [js-builder  9/13] COPY public public        1.4s
 => CANCELED [go-builder 13/13] RUN make build-go        1001.8s
 => [js-builder 10/13] COPY tools tools        0.1s
 => [js-builder 11/13] COPY scripts scripts        0.1s
 => [js-builder 12/13] COPY emails emails        0.0s
 => ERROR [js-builder 13/13] RUN yarn build        997.5s
 > [js-builder 13/13] RUN yarn build:
executor failed running [/bin/sh -c yarn build]: exit code: 129
Solution for the Issue executor failed running [/bin/sh -c yarn build]: exit code: 129
Might be due to Yarn parallelism. I solved by Increasing Docker CPU: 4, Mem: 4GB, Swap: 4GB.
and added
RUN export NODE_OPTIONS="--max-old-space-size=8192"
to the Docker file.
