Grafana 8.2, Mac OS monterey (Mac M1)
** Build a docker image on Mac OS M1
** docker build --build-arg “GRAFANA_VERSION=latest” --platform linux/arm64 -t custom -f Dockerfile .
Getting docker build error in yarn build
[+] Building 289.2s (44/48)
=> [internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 120B 0.0s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 118B 0.0s
=> [internal] load metadata for docker.io/library/alpine:3.14.3 22.4s
=> [internal] load metadata for docker.io/library/golang:1.17.3-alpine3.14 23.3s
=> [internal] load metadata for docker.io/library/node:16-alpine3.14 23.3s
=> [auth] library/node:pull token for registry-1.docker.io 0.0s
=> [auth] library/alpine:pull token for registry-1.docker.io 0.0s
=> [auth] library/golang:pull token for registry-1.docker.io 0.0s
=> [go-builder 1/13] FROM docker.io/library/golang:1.17.3-alpine3.14@sha256:55da409cc0fe11df63a7d6962fbefd1321fedc305d9969da636876893e289e2d 0.0s
=> [internal] load build context 0.9s
=> => transferring context: 1.59MB 0.7s
=> [stage-2 1/13] FROM docker.io/library/alpine:3.14.3@sha256:635f0aa53d99017b38d1a0aa5b2082f7812b03e3cdb299103fe77b5c8a07f1d2 0.0s
=> [js-builder 1/13] FROM docker.io/library/node:16-alpine3.14@sha256:60ef0bed1dc2ec835cfe3c4226d074fdfaba571fd619c280474cc04e93f0ec5b 0.0s
=> CACHED [stage-2 2/13] WORKDIR /usr/share/grafana 0.0s
=> CACHED [stage-2 3/13] RUN apk add --no-cache ca-certificates bash tzdata musl-utils 0.0s
=> CACHED [stage-2 4/13] RUN apk add --no-cache openssl ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main 0.0s
=> CACHED [stage-2 5/13] RUN apk upgrade ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main 0.0s
=> CACHED [stage-2 6/13] RUN apk info -vv | sort 0.0s
=> CACHED [stage-2 7/13] COPY conf ./conf 0.0s
=> CACHED [stage-2 8/13] RUN if [ ! $(getent group "0") ]; then addgroup -S -g 0 grafana; fi 0.0s
=> CACHED [stage-2 9/13] RUN export GF_GID_NAME=$(getent group 0 | cut -d':' -f1) && mkdir -p "/usr/share/grafana/.aws" && adduser -S -u 472 -G "$GF_GID_NAME" grafana && mkdir -p "/etc/graf 0.0s
=> CACHED [js-builder 2/13] WORKDIR /grafana 0.0s
=> CACHED [js-builder 3/13] COPY package.json yarn.lock .yarnrc.yml ./ 0.0s
=> CACHED [js-builder 4/13] COPY .yarn .yarn 0.0s
=> CACHED [js-builder 5/13] COPY packages packages 0.0s
=> CACHED [js-builder 6/13] COPY plugins-bundled plugins-bundled 0.0s
=> CACHED [js-builder 7/13] RUN yarn install 0.0s
=> CACHED [js-builder 8/13] COPY tsconfig.json .eslintrc .editorconfig .browserslistrc .prettierrc.js babel.config.json ./ 0.0s
=> CACHED [js-builder 9/13] COPY public public 0.0s
=> CACHED [js-builder 10/13] COPY tools tools 0.0s
=> CACHED [js-builder 11/13] COPY scripts scripts 0.0s
=> CACHED [js-builder 12/13] COPY emails emails 0.0s
=> ERROR [js-builder 13/13] RUN yarn build 264.7s
=> CACHED [go-builder 2/13] RUN apk add --no-cache gcc g++ make 0.0s
=> CACHED [go-builder 3/13] WORKDIR /grafana 0.0s
=> CACHED [go-builder 4/13] COPY go.mod go.sum embed.go Makefile build.go package.json ./ 0.0s
=> CACHED [go-builder 5/13] COPY cue cue 0.0s
=> CACHED [go-builder 6/13] COPY packages/grafana-schema packages/grafana-schema 0.0s
=> CACHED [go-builder 7/13] COPY public/app/plugins public/app/plugins 0.0s
=> CACHED [go-builder 8/13] COPY pkg pkg 0.0s
=> CACHED [go-builder 9/13] COPY scripts scripts 0.0s
=> CACHED [go-builder 10/13] COPY cue.mod cue.mod 0.0s
=> CACHED [go-builder 11/13] COPY .bingo .bingo 0.0s
=> CACHED [go-builder 12/13] RUN go mod verify 0.0s
=> CANCELED [go-builder 13/13] RUN make build-go 264.8s
> [js-builder 13/13] RUN yarn build:
executor failed running [/bin/sh -c yarn build]: exit code: 129
