Build custom Docker Grafana from source
    I forked the latest github sources from grafana.
    I managed to change the frontend according to our needs and also successfully build the backend and frontend on a local machine. I’m a bit stuck how to create a docker image from our own build.
    Tried to copy the public/build folder to the already existing docker image of grafana but it’s not showing out changes.
What is the best way of creating a own docker grafana image from a forked grafana repository and own build.
Any help woul be great.
Thanks
There is a Dockerfile in the root directory of Grafana. Using the following command, we can build Grafana image:
docker build -t grafana-custom -f Dockerfile .
The image created might be bigger than what Grafana image is.
docker images | grep grafana-custom        [22:42:24]
grafana-custom        latest                   8cef3c310a78   3 minutes ago    532MB
Here we built the image via GitHub pipeline for a project.
Here’s the link to documentation.
