10.2.2 -
I’m trying to expose grafana dashboard with a custom domain… -
I’m keeping grafana dashboard behind azure app gateway -
What happened?
Whenever I try to add any sources or interact with anything in grafana after login its throwing 403 origin not allowed -
It should allow me to create dashboards or add data sources -
grafana.ini: >
[analytics]check_for_updates = true
[grafana_net]
url = grafana.net
[log]
mode = console
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[server]
domain = ‘test’
root_url= ‘test/grafana’
serve_from_sub_path = true
[auth.generic_oauth]
enabled = true
name = OAuth
allow_sign_up = true
client_id = grafanatests
scopes = openid profile email grafanatests
auth_url =
https://test-idp/connect/authorizetoken_url =test-idp/connect/token(Its base url is proper as auth url.just removed as discussion not allowing to add more than 2 links)
api_url = test-idp/connect/userinfo(Its base url is proper as auth url.just removed as discussion not allowing to add more than 2 links)
Origin not allowed 403
Your API gateway must forward proper host header, which you configured in server domain section. So check documentation of your gateway how to do that.
