I was using Grafana 8.0.6 and it was running fine but with 9.4.17 or latest I am getting 403 errors
- What are you trying to achieve?
I want to have Grafana running behind an application gateway on a path of an existing domain.
- How are you trying to achieve it?
I am using Terraform to provision a Linux Web App (Grafana) and an Application Gateway to terminate SSL, though for testing purposes I am only using HTTP at the moment.
- What happened?
When I run an older version of Grafana everything works as expected with this configuration:
app_settings = {
DOCKER_ENABLE_CI = "true"
GF_SECURITY_X_XSS_PROTECTION = "false"
GF_SERVER_DOMAIN = "domain.net"
GF_LIVE_ALLOWED_ORIGINS = "*"
GF_SERVER_ROOT_URL = "%(protocol)s://%(domain)s:%(http_port)s/grafana/"
GF_SERVER_SERVE_FROM_SUB_PATH = "true"
GF_SECURITY_ADMIN_USER = "admin"
GF_SECURITY_ADMIN_PASSWORD = var.gf_password
I have set the container hostname as the backend setting in the Azure Gateway.
name = "prod-grafana-backend-http-settings"
pick_host_name_from_backend_address = false
host_name = azurerm_linux_web_app.grafana-web-app.default_hostname
cookie_based_affinity = "Enabled"
path = "/grafana/"
port = 80
protocol = "Http"
request_timeout = 30
probe_name = "${var.appgw_probe[terraform.workspace]}-gf"
I would expect Grafana to work without 403 errors.
- Can you copy/paste the configuration(s) that you are having problems with?
Pasted above
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
I’ve looked around on the forum but everything seems to discuss nginx or Apache configuration.
