I have successfully configured Grafana to authenticate using AWS Cogntio and now I’m trying to find how I can access the user’s idToken so that I can use it to call our ElasticSearch service from my custom plugin.
How do I get the idToken of the logged in user in my datasource.ts file?
I guess that Cognito is only for Kibana authentication, but not for AWS ES. I would use Signature Version 4 authentication, which is already available: Elasticsearch | Grafana Labs
That makes more sense. I would check Forward OAuth Identity source code functionality (it is working with access token, so you may find also ID token there):
Are you able to point me to the source code for “Forward OAuth Identity”? I thought this was a plugin but I couldn’t find it in the plugin store. What is the screenshot you shared from?
