Generic_oauth (AWS Cognito) returns empty token
Hi there,
at the moment I’m trying to use AWS Cognito as oauth server for our Grafana installation (version 4.3.1)
I made the changes in the auth.generic_oauth section in the grafana.ini file.
Unfortunately i received the error message “create account failed”. After some research i found out that a user is added in the internal sqlite3 database with the information that is returned from the oauth server.
I opened the log file (level: trace) and found out that the returned information (of the token) from Cognito is empty.
See log entries:
t=2018-04-30T07:01:30+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=302 remote_addr=MY_ADDRESS time_ms=0 size=355
t=2018-04-30T07:01:30+0000 lvl=dbug msg=“OAuthLogin Got token” logger=context userId=0 orgId=0 uname=
t=2018-04-30T07:01:30+0000 lvl=eror msg=“Invalid API key” logger=context error=“Invalid Api Key”
t=2018-04-30T07:01:30+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/ status=401 remote_addr=GRAFANA_ADDR time_ms=0 size=29
t=2018-04-30T07:01:30+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/emails status=401 remote_addr=GRAFANA_ADR time_ms=0 size=29
t=2018-04-30T07:01:30+0000 lvl=dbug msg=“OAuthLogin got user info” logger=context userId=0 orgId=0 uname= userInfo="&{Name: Email: Login: Company: Role:}"
t=2018-04-30T07:01:30+0000 lvl=eror msg=“Failed to create account” logger=context userId=0 orgId=0 uname= error=“UNIQUE constraint failed: user.email”
t=2018-04-30T07:01:30+0000 lvl=eror msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=MY_ADDRESS time_ms=138 size=688
I’m not sure why the Invalid API key error occurs?
If i test with Postman no error occurs and also the token contains the requested information: openid + profile + email. I don’t know why Grafana isn’t able to receive this information.
As a second approach I added another app client without client_secret, but in this case Grafana returns an invalid_client error when communicating with AWS Cognito which is also a bit confusing for me because also this app client works when I test with postman…
It would be great if you could help me!
Best regards
Has anyone ever contacted you about this fix?
What did you do to resolve this issue? I’m getting similar Invalid Api Key errors in my Grafana logs too.
