9.4.7 -
Using oauth to call the backend API -
I am using AWS Cognito for oauth. I am able to login via oauth.
After login, I have configured JSON data source with forward oauth identity option enabled.
I have configured the URL (AWS API gateway URL) in the data source which I can access using the ID Token from Postman. -
What happened?
On trying to Save the Data source settings, it says error getting data frame. 401 Unauthorized.
If I Add custom Authorization header and manually pass the ID token (as bearer token) then it works.
Is there any addition configuration required that I am missing?
It should have called the api url and return the json response. -
Let me know what additional details I have to provide. oauth setting are:
#################################### Generic OAuth #######################
[auth.generic_oauth]
name = Cognito
icon = signin
enabled = true
allow_sign_up = true
client_id = XXXXXXXXXXXXXX
client_secret = YYYYYYYYYYYYYYYYYYYY
scopes = email profile aws.cognito.signin.user.admin openid
empty_scopes = false
email_attribute_name = email:primary
email_attribute_path =
login_attribute_path =
name_attribute_path =
role_attribute_path =
role_attribute_strict = false
groups_attribute_path =
id_token_attribute_name =
team_ids_attribute_path =
auth_url = https://iotasmarthome.auth.ap-south-1.amazoncognito.com/oauth2/authorize
token_url = https://iotasmarthome.auth.ap-south-1.amazoncognito.com/oauth2/token
api_url = not able to put more than two links…
teams_url =
allowed_domains =
;team_ids =
allowed_organizations =
tls_skip_verify_insecure = false
tls_client_cert =
tls_client_key =
tls_client_ca =
updated to true
use_pkce = false
error getting data frame. 401 Unauthorized -
Yes, I tried all instructions but it is not working
