Does Forward OAuth Identity work with auth.jwt
    Helm Chart grafana-6.43.0/9.2.1
    Find out if “Forward OAuth Identity” is supposed to work when the user is authenticated via auth.jwt
  • What happened?
    auth.jwt is configured and user is able to login. However, there seems to problems getting the token forwarded to the datasource. The following is present in the logs
logger=oauthtoken t=2022-12-09T12:37:44.638728586Z level=error msg=“failed to get OAuth connector” provider=jwt error=“failed to find oauth provider for "jwt"”
    auth.jwt:
    enabled: true
    jwk_set_url: https://DEX_FQDN/dex/keys
    role_attribute_path: “contains(groups[*], ‘GrafanaAdmin’) && ‘GrafanaAdmin’ || ‘Viewer’”
    url_login: true
    auto_sign_up: true
    enable_login_token: true
    header_name: X-Forwarded-Access-Token
    allow_assign_grafana_admin: true
    username_claim: “name”
