My map panel appears blurry , also the markers and any text. I am running a windows laptop but it appears the same on other computers.
There was a similar issue at
Geomap: Basemap layer appears blurry/pixelated on retina display · Issue #81195 · grafana/grafana · GitHub but it specified retina displays
this is the display in a panel:
and to give an idea , this is a screenshot next to a google map on the same laptop:
The google map is pin sharp (although I dont know how this screen shot will render in this message box)
It is absolutely sure that the google map is pin sharp and the GeoMap is blurry on the panel. Its the same in other browsers and also if i restore to kiosk mode.
Its quite unusable for any professional applications at the moment.
I would be grateful for any advice . many thanks
