It’s provided from my company -
I want that the Gauge just shows an 1 and not a 2 or even more. I have 4 severs ( different stages ) all running the same windows service and I want to check if multiple services are running or not for an overview. If I do so then its adding up like I checkt for 2 different services on one server and it shows an 2 as seen below →
N/A -
What happened?+
N/A -
N/A -
No -
No didn’t found help online.
Maybe an idea from me is that I just map the value from to 1 bust is there any other solution?
What is your data source
Prometheus / Thanos
