Gauge chart should give me the count of requests
Currently I use a Grafana dashboard with Loki datasource to monitor my apps in Azure kubernetes Service. The logs do not follow a logfmt/json etc.,. and every deployment creates a new pod.
i use the Gauge panel to display number of requests however the panel seems to be stuck at 1000 despite the fact that there were >1000 requests. i couldnt find any option that displays threshold.
By using a query as shown below and applying a transformation of labels to fields
What happened?
I ran a stress test with ~2000 requests but the gauge panel is stuck at 1000 -
It should show a number ~2000 -
sounds like you might have some sort of max setting at 1000. I would check the min max settings in the panel editor, because the gauge should not get capped like that. The text will resize dynamically as the number gets larger
I would maybe share your transformation and what your transformed data looks like in the table panel so we can try and mock it up
