I have a counter table which counts certain data per day (like number of requests). I have defined a time series graph in grafana that shows the request per days.
Data looks like that:
1.03.2024 4
2.03.2024 6
3.03.2024 2
Sql query looks like this:
SELECT SUM(count), timestamp FROM counter WHERE $__timeFilter(timestamp) GROUP BY timestamp
That works so far but now i would like that the graph shows the absolute/increasing values and not the delta. The data point in the graph should be like that:
1.03.2024 4
2.03.2024 10
3.03.2024 12
Is there a build in function in grafana that adds the previous values to the current value in a time series graph? Is there an other way to achieve this in grafana/sql or do i have to count the total value in the counter table as a separate field?
Grafana 10.3.x and postgresql is used
thank you
