Hi dev team,
I am proud to present you the latest version of Flowcharting available in plugin section
[0.5.0 SNAPSHOT] - 2019-10-13
Added
- 2 new modes for “Update text value” (See example)
- Append (Space) : Concat metrics with a space as a separator
- Append (New line) : Concat metrics with a line break
- Variabilization in “Url” for link mapping (See example)
- New check box to allow download images from draw.io (See example)
- New editor option :
- Choose other editor draw.io like internal website
- Choose the theme of editor
- New identification mode for shapes when mouse cursor is over the rules or the mapping (See example)
- Support Dynamic shapes like Floorplan, isometric plans and more (See example)
- New color mode for no SVG object like pictures/cliparts/images (See example)
- Graphs in tooltip (See example)
- Color graph with defined colors in threshold
- Size of graph (See example)
- Define the orientation in tooltip for each metrics/graph in tooltips : horizontal or vertical (See example)
- Some optimizations, Display is twice as fast on load.
Fixed
- Fix color to reset when “Color on” is “Always/Critical” and metric is OK
- Fix border to empty instead black when “color mode” is “Fill” (issue #24)
- Fix error when “Value On” is not “When metric displayed”
- Fix Link (issue #37)
- Fix hyperlink text appears in white over flowchart (issue #45)
- Fix “Multiple FlowCharts On a Dashboard”, when edit, both are the same draw (issue #48)
- Fix options after reload or variable changed (issue #44)
- Fix auto reset zoom/unzoom when data refreshed, only ESC or change options on flowchart reset zoom now (issue #38)
- Fix error for BPNM shapes (Issue #51)
- Fix display when center and scale are checked on flowchart options.
- Fix Zoom with mouse wheel for firefox and Edge.
Best reguards,
Arnaud
