Hi contributors,
I am proud to annouce version 0.3.0 de flowcharting, pull request in progress.
Full documentation with animated examples
Some screenshots
New banner
Easter egg hidden in our dashboads
Home automation example
[0.3.0] - 2019-05-07
Added
/!\ Possible breaking change with 0.2.0 and 0.2.5 but it will compatible with next release.
- Migration process for next release.
- Dynamic documentation/Examples on popover (thx SCHKN)
- Params link option, add params of dashboard to link.
- Full review of code (ES6 Class mode)
- Unit test with jest to increase quality
- Fill/text/stoke rules on the same object is possible.
- Mapping selector helper (chain in mapping)
- Icon overlay state (display icon warning when NOK)
- Implemented the conditions to display text according to the states.
- new inspect Tab with :
- Renamer ID (double click on ID)
- State status
- Debug mode
- Custom Link Mapping overrite.
Fixed
- Substring replace on text (Issue #8)
- Editor object not found Exception (Issue #1)
- Original Link (Issue #9)
- Fixed Change the colors (Issue #14)
- Fixed Unit (Issue #12)
Project site
Best regards,
Arnaud
