Hello. First of all i want to thank you for your software. It really helped us a lot building analytic and monitoring dashboards.
I have some question “how to” :
How can i get information from one single stat panel to another? I have two single stat panels. Each one with query. I want to transfer the main value from query of one single stat to first Thresholds value, so it will be more flexible. Can it be something line methods Single_stat1.getvalue() ? Or i need to put same query that i used in first single stat to thresholds values?
As you see, its red because of same Thresholds. But it needed to be green and filled fully, because solved issues = created issues. It need to be more flexible because we dont know how much issues woulde be created each day, and how much will be solved with procentage of them
