Is it feasible to transfer the value from one panel to another panel in Grafana?
Hi All,
Is there a way to utilize the value from one panel in another panel within Grafana?
Let’s say,
Stats Panel A : 37%
Stats Panel B : (10% + Stats Panel A)
= 10% + 37%
= 47%
Note: Both values are dynamic.
Hi @asuwini
Have you considered using a transformation, like this?
Thank you for your valuable support! :+1: @grant2
I have the used “Add field from calculation” transform and got the output
