10.2.3
- What are you trying to achieve?
I am looking up the integer id number of a named quantity in a PostgreSQL table - this is done via a drop down variable where I select the name of the variables loaded from this table. This id number is used in the name of the TimescaleDB table for that variable, named in the
format var_${vartid:06d}
I am then trying to graph the variable, using:
SELECT time, c0 AS "${name}" FROM var_${vartid:06d}
- What happened?
db query error: pq: relation "var_153" does not exist
Clearly this kind of string formatting is not supported (in this syntax, at least).
A query of the var_000153
table
Is this kind of basic string formatting available in Grafana, either in variable definitions or graph definitions? Googling hasn’t really turned up anything relevant so far.
