Variable value being interpreted as a column name
I am trying to create a simple dashboard, with a table to show the output of a query that uses a variable. I am connecting to a Vertica database. However, I get an error indicating that Grafana is interpreting the selected value of the variable as a column name. Please see the details below, including the screenshot, which shows the query I’ve defined.
  • What Grafana version and what operating system are you using? 10.1.2
    Trying to create a dashboard with a variable and time filter
  • What happened?
    I get an error that suggests that Grafana is using the selected value of the variable as a column name.
    The query should match the values of a column, configuration_item_display_label, to the selected value of the variable $host
Thanks
-Ankit
Welcome @ankitdm
Please share the query for that variable?
Thanks @yosiasz , here is the variable query:
SELECT DISTINCT configuration_item_display_label
FROM opr_hi_duration_1d
WHERE LOWER(configuration_item_type_name) IN (‘node’)
what version of grafana is it and what is your data source. it works for me.
I’m on 10.1.2. My data source is Vertica database, using the vertica-grafana-datasource 2.1.0 plugin.
Note that the variable dropdown works for me too, but the panel doesn’t load any data, with the error I pasted in my original post. How does your query look?
Thanks
-Ankit
Thank you @yosiasz , that did the trick.
