SQL query with variable (26 characters long)
    8.0.1
  • What are you trying to achieve? I am using a SQL datasource with some variables. I defined a variable with a text and id value. The ID value is a numeric field with 26 characters.
When I use it in a query though, it does not show the actual value but something like 5.221325173822737e**+25**. This causes that my queries don’t work or mostly don’t work. How can I have Grafana show the actual value instead of a sum.
  • What did you expect to happen? Show the actual value instead of “+25”
Thanks in advance!
Overrides?
Have the same issue even with 8 digit HEX values for serial numbers in my data
01005E26 = 1005 e + 26 ( Grafana defaults )
See here with one of my fields or you can do a whole column etc
Doesn’t seem to work. Overrides aren’t for variables as well though. See below:
I found a solution. I converted my value to varchar via my SQL query. It now shows it correctly.
convert(varchar(55), id) as __value
Thanks for the help!
I had the same item happen with a datetime in mysql… I had to use cast as it showed up as a int
SELECT cast(last_seen_at as char) FROM user WHERE login=’${__user.login}’
if I did just last_seen_at it was a really ugly number that I had lots of digits…
