File permission issues leading to server errors
Grafana 12.3.0 on Arch Linux (installed from Arch repositories).
I’m trying to set up system monitoring through Node Exporter.
Using Grafana, Prometheus, and prometheus-node-exporter
  • What happened?
I set up Prometheus, prometheus-node-exporter, added them as a Grafana source, rebooted my system, and now I’m getting HTTP 500 errors when I try and access my Grafana instance (I can’t even log in). Before the reboot, systemd logs for Grafana showed errors which seemed to be related to file access errors.
I expected things to work without getting HTTP 500s from my Grafana instances.
grafana.ini (shortened, but should include all changes I made from the default):
##################### Grafana Configuration Example #####################
# Everything has defaults so you only need to uncomment things you want to
# change
# possible values : production, development
;app_mode = production
# instance name, defaults to HOSTNAME environment variable value or hostname if HOSTNAME var is empty
;instance_name = ${HOSTNAME}
#################################### Paths ####################################
[paths]
# Path to where grafana can store temp files, sessions, and the sqlite3 db (if that is used)
;data = /var/lib/grafana
# Temporary files in `data` directory older than given duration will be removed
;temp_data_lifetime = 24h
# Directory where grafana can store logs
;logs = /var/log/grafana
# Directory where grafana will automatically scan and look for plugins
;plugins = /var/lib/grafana/plugins
# folder that contains provisioning config files that grafana will apply on startup and while running.
;provisioning = conf/provisioning
# Directories that are permitted to contain local repositories.
# This is a list. Each entry is delimited by a pipe (|). No leading or trailing spaces are supported.
# These do not need to be absolute paths, in which case they'll be relative to the path where you are running Grafana.
# Empty entries will return an error, unless the string is just a single pipe.
# Example: permitted_provisioning_paths = /tmp|/etc/grafana/repositories|conf/provisioning
;permitted_provisioning_paths = devenv/dev-dashboards|conf/provisioning
#################################### Server ####################################
[server]
# Protocol (http, https, h2, socket)
;protocol = http
# Minimum TLS version allowed. By default, this value is empty. Accepted values are: TLS1.2, TLS1.3. If nothing is set TLS1.2 would be taken
;min_tls_version = ""
# The ip address to bind to, empty will bind to all interfaces
http_addr = 127.0.0.1
# The http port to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = mon.prusa.net
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
# enforce_domain = true
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
;root_url = %(protocol)s://%(domain)s:%(http_port)s/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = false
# Log web requests
;router_logging = false
# the path relative working path
;static_root_path = public
# enable gzip
;enable_gzip = false
# https certs & key file
;cert_file =
;cert_key =
# optional password to be used to decrypt key file
;cert_pass =
# Certificates file watch interval
;certs_watch_interval =
# Unix socket gid
# Changing the gid of a file without privileges requires that the target group is in the group of the process and that the process is the file owner
# It is recommended to set the gid as http server user gid
# Not set when the value is -1
;socket_gid =
# Unix socket mode
;socket_mode =
# Unix socket path
;socket =
# CDN Url
;cdn_url =
# Sets the maximum time using a duration format (5s/5m/5ms) before timing out read of an incoming request and closing idle connections.
# `0` means there is no timeout for reading the request.
;read_timeout = 0
# This setting enables you to specify additional headers that the server adds to HTTP(S) responses.
[server.custom_response_headers]
#exampleHeader1 = exampleValue1
#exampleHeader2 = exampleValue2
[environment]
# Sets whether the local file system is available for Grafana to use. Default is true for backward compatibility.
;local_file_system_available = true
#################################### GRPC Server #########################
;[grpc_server]
;network = "tcp"
;address = "127.0.0.1:10000"
;use_tls = false
;cert_file =
;key_file =
;max_recv_msg_size =
;max_send_msg_size =
# this will log the request and response for each unary gRPC call
;enable_logging = false
#################################### Database ####################################
[database]
# You can configure the database connection by specifying type, host, name, user and password
# as separate properties or as on string using the url properties.
# Either "mysql", "postgres" or "sqlite3", it's your choice
;type = sqlite3
;host = 127.0.0.1:3306
;name = grafana
;user = root
# If the password contains # or ; you have to wrap it with triple quotes. Ex """#password;"""
;password =
# Use either URL or the previous fields to configure the database
# Example: mysql://user:secret@host:port/database
;url =
# Set to true or false to enable or disable high availability mode.
# When it's set to false some functions will be simplified and only run in-process
# instead of relying on the database.
# Only set it to false if you run only a single instance of Grafana.
;high_availability = true
# Max idle conn setting default is 2
;max_idle_conn = 2
# Max conn setting default is 0 (mean not set)
;max_open_conn =
# Connection Max Lifetime default is 14400 (means 14400 seconds or 4 hours)
;conn_max_lifetime = 14400
# Set to true to log the sql calls and execution times.
;log_queries =
# For "postgres", use either "disable", "require" or "verify-full"
# For "mysql", use either "true", "false", or "skip-verify".
;ssl_mode = disable
# For "postgres", use either "1" to enable or "0" to disable SNI
;ssl_sni =
# Database drivers may support different transaction isolation levels.
# Currently, only "mysql" driver supports isolation levels.
# If the value is empty - driver's default isolation level is applied.
# For "mysql" use "READ-UNCOMMITTED", "READ-COMMITTED", "REPEATABLE-READ" or "SERIALIZABLE".
;isolation_level =
;ca_cert_path =
;client_key_path =
;client_cert_path =
;server_cert_name =
# For "sqlite3" only, path relative to data_path setting
;path = grafana.db
# For "sqlite3" only. cache mode setting used for connecting to the database. (private, shared)
;cache_mode = private
# For "sqlite3" only. Enable/disable Write-Ahead Logging, https://sqlite.org/wal.html. Default is false.
;wal = false
# For "mysql" and "postgres" only. Lock the database for the migrations, default is true.
;migration_locking = true
# For "mysql" and "postgres" only. How many seconds to wait before failing to lock the database for the migrations, default is 0.
;locking_attempt_timeout_sec = 0
# For "sqlite" only. How many times to retry query in case of database is locked failures. Default is 0 (disabled).
;query_retries = 0
# For "sqlite" only. How many times to retry transaction in case of database is locked failures. Default is 5.
;transaction_retries = 5
# Set to true to add metrics and tracing for database queries.
;instrument_queries = false
#################################### Cache server #############################
[remote_cache]
# Either "redis", "memcached" or "database" default is "database"
;type = database
# cache connectionstring options
# database: will use Grafana primary database.
# redis: config like redis server e.g. `addr=127.0.0.1:6379,pool_size=100,db=0,username=grafana,password=grafanaRocks,ssl=false`. Only addr is required. ssl may be 'true', 'false', or 'insecure'.
# memcache: 127.0.0.1:11211
;connstr =
# prefix prepended to all the keys in the remote cache
; prefix =
# This enables encryption of values stored in the remote cache
;encryption =
#################################### Data proxy ###########################
[dataproxy]
# This enables data proxy logging, default is false
;logging = false
# How long the data proxy waits to read the headers of the response before timing out, default is 30 seconds.
# This setting also applies to core backend HTTP data sources where query requests use an HTTP client with timeout set.
;timeout = 30
# How long the data proxy waits to establish a TCP connection before timing out, default is 10 seconds.
;dialTimeout = 10
# How many seconds the data proxy waits before sending a keepalive probe request.
;keep_alive_seconds = 30
# How many seconds the data proxy waits for a successful TLS Handshake before timing out.
;tls_handshake_timeout_seconds = 10
# How many seconds the data proxy will wait for a server's first response headers after
# fully writing the request headers if the request has an "Expect: 100-continue"
# header. A value of 0 will result in the body being sent immediately, without
# waiting for the server to approve.
;expect_continue_timeout_seconds = 1
# Optionally limits the total number of connections per host, including connections in the dialing,
# active, and idle states. On limit violation, dials will block.
# A value of zero (0) means no limit.
;max_conns_per_host = 0
# The maximum number of idle connections that Grafana will keep alive.
;max_idle_connections = 100
# How many seconds the data proxy keeps an idle connection open before timing out.
;idle_conn_timeout_seconds = 90
# If enabled and user is not anonymous, data proxy will add X-Grafana-User header with username into the request, default is false.
;send_user_header = false
# Limit the amount of bytes that will be read/accepted from responses of outgoing HTTP requests.
;response_limit = 0
# Limits the number of rows that Grafana will process from SQL data sources.
;row_limit = 1000000
# Sets a custom value for the `User-Agent` header for outgoing data proxy requests. If empty, the default value is `Grafana/<BuildVersion>` (for example `Grafana/9.0.0`).
;user_agent =
#################################### Analytics ####################################
[analytics]
# Server reporting, sends usage counters to stats.grafana.org every 24 hours.
# No ip addresses are being tracked, only simple counters to track
# running instances, dashboard and error counts. It is very helpful to us.
# Change this option to false to disable reporting.
;reporting_enabled = true
# The name of the distributor of the Grafana instance. Ex hosted-grafana, grafana-labs
;reporting_distributor = grafana-labs
# Set to false to disable all checks to https://grafana.com
# for new versions of grafana. The check is used
# in some UI views to notify that a grafana update exists.
# This option does not cause any auto updates, nor send any information
# only a GET request to https://grafana.com/api/grafana/versions/stable to get the latest version.
;check_for_updates = true
# for new versions of plugins. The check is used
# in some UI views to notify that a plugin update exists.
# only a GET request to https://grafana.com to get the latest versions.
;check_for_plugin_updates = true
# Google Analytics universal tracking code, only enabled if you specify an id here
;google_analytics_ua_id =
# Google Analytics 4 tracking code, only enabled if you specify an id here
;google_analytics_4_id =
# When Google Analytics 4 Enhanced event measurement is enabled, we will try to avoid sending duplicate events and let Google Analytics 4 detect navigation changes, etc.
;google_analytics_4_send_manual_page_views = false
# Google Tag Manager ID, only enabled if you specify an id here
;google_tag_manager_id =
# Rudderstack write key, enabled only if rudderstack_data_plane_url is also set
;rudderstack_write_key =
# Rudderstack data plane url, enabled only if rudderstack_write_key is also set
;rudderstack_data_plane_url =
# Rudderstack SDK url, optional, only valid if rudderstack_write_key and rudderstack_data_plane_url is also set
;rudderstack_sdk_url =
# Rudderstack Config url, optional, used by Rudderstack SDK to fetch source config
;rudderstack_config_url =
# Rudderstack Integrations URL, optional. Only valid if you pass the SDK version 1.1 or higher
;rudderstack_integrations_url =
# Intercom secret, optional, used to hash user_id before passing to Intercom via Rudderstack
;intercom_secret =
# Application Insights connection string. Specify an URL string to enable this feature.
;application_insights_connection_string =
# Optional. Specifies an Application Insights endpoint URL where the endpoint string is wrapped in backticks ``.
;application_insights_endpoint_url =
# Controls if the UI contains any links to user feedback forms
;feedback_links_enabled = true
# Static context that is being added to analytics events
;reporting_static_context = grafanaInstance=12, os=linux
# Logs interaction events to the browser javascript console, intended for development only
;browser_console_reporter = false
#################################### Security ####################################
[security]
# disable creation of admin user on first start of grafana
;disable_initial_admin_creation = false
# default admin user, created on startup
;admin_user = admin
# default admin password, can be changed before first start of grafana,  or in profile settings
;admin_password = admin
# default admin email, created on startup
;admin_email = admin@localhost
# used for signing
;secret_key = SW2YcwTIb9zpOOhoPsMm
# current key provider used for envelope encryption, default to static value specified by secret_key
;encryption_provider = secretKey.v1
# list of configured key providers, space separated (Enterprise only): e.g., awskms.v1 azurekv.v1
;available_encryption_providers =
# disable gravatar profile images
;disable_gravatar = false
# data source proxy whitelist (ip_or_domain:port separated by spaces)
;data_source_proxy_whitelist =
# disable protection against brute force login attempts
;disable_brute_force_login_protection = false
# max number of failed login attempts before user gets locked
;brute_force_login_protection_max_attempts = 5
# disable protection against brute force login attempts by IP address
; disable_ip_address_login_protection = true
# set to true if you host Grafana behind HTTPS. default is false.
cookie_secure = true
# set cookie SameSite attribute. defaults to `lax`. can be set to "lax", "strict", "none" and "disabled"
cookie_samesite = strict
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
;allow_embedding = false
# Set to true if you want to enable http strict transport security (HSTS) response header.
# HSTS tells browsers that the site should only be accessed using HTTPS.
;strict_transport_security = false
# Sets how long a browser should cache HSTS. Only applied if strict_transport_security is enabled.
;strict_transport_security_max_age_seconds = 86400
# Set to true if to enable HSTS preloading option. Only applied if strict_transport_security is enabled.
;strict_transport_security_preload = false
# Set to true if to enable the HSTS includeSubDomains option. Only applied if strict_transport_security is enabled.
;strict_transport_security_subdomains = false
# Set to true to enable the X-Content-Type-Options response header.
# The X-Content-Type-Options response HTTP header is a marker used by the server to indicate that the MIME types advertised
# in the Content-Type headers should not be changed and be followed.
;x_content_type_options = true
# Set to true to enable the X-XSS-Protection header, which tells browsers to stop pages from loading
# when they detect reflected cross-site scripting (XSS) attacks.
;x_xss_protection = true
# Enable adding the Content-Security-Policy header to your requests.
# CSP allows to control resources the user agent is allowed to load and helps prevent XSS attacks.
content_security_policy = true
# Set Content Security Policy template used when adding the Content-Security-Policy header to your requests.
# $NONCE in the template includes a random nonce.
# $ROOT_PATH is server.root_url without the protocol.
content_security_policy_template = """script-src 'self' 'unsafe-eval' 'unsafe-inline' 'strict-dynamic' $NONCE;object-src 'none';font-src 'self';style-src 'self' 'unsafe-inline' blob:;img-src * data:;base-uri 'self';connect-src 'self' grafana.com ws://$ROOT_PATH wss://$ROOT_PATH;manifest-src 'self';media-src 'none';form-action 'self';"""
# Enable adding the Content-Security-Policy-Report-Only header to your requests.
# Allows you to monitor the effects of a policy without enforcing it.
;content_security_policy_report_only = false
# Set Content Security Policy Report Only template used when adding the Content-Security-Policy-Report-Only header to your requests.
;content_security_policy_report_only_template = """script-src 'self' 'unsafe-eval' 'unsafe-inline' 'strict-dynamic' $NONCE;object-src 'none';font-src 'self';style-src 'self' 'unsafe-inline' blob:;img-src * data:;base-uri 'self';connect-src 'self' grafana.com ws://$ROOT_PATH wss://$ROOT_PATH;manifest-src 'self';media-src 'none';form-action 'self';"""
# Controls if old angular plugins are supported or not.
;angular_support_enabled = false
# List of additional allowed URLs to pass by the CSRF check, separated by spaces. Suggested when authentication comes from an IdP.
;csrf_trusted_origins = example.com
# List of allowed headers to be set by the user, separated by spaces. Suggested to use for if authentication lives behind reverse proxies.
;csrf_additional_headers =
# The CSRF check will be executed even if the request has no login cookie.
;csrf_always_check = false
# Comma-separated list of plugins ids that will be loaded inside the frontend sandbox
# Currently behind the feature flag pluginsFrontendSandbox
;enable_frontend_sandbox_for_plugins =
# Comma-separated list of paths for POST/PUT URL in actions. Empty will allow anything that is not on the same origin
;actions_allow_post_url =
[security.encryption]
# Defines the time-to-live (TTL) for decrypted data encryption keys stored in memory (cache).
# Please note that small values may cause performance issues due to a high frequency decryption operations.
;data_keys_cache_ttl = 15m
# Defines the frequency of data encryption keys cache cleanup interval.
# On every interval, decrypted data encryption keys that reached the TTL are removed from the cache.
;data_keys_cache_cleanup_interval = 1m
#################################### Snapshots ###########################
[snapshots]
# set to false to remove snapshot functionality
;enabled = true
# snapshot sharing options
;external_enabled = true
;external_snapshot_url = https://snapshots.raintank.io
;external_snapshot_name = Publish to snapshots.raintank.io
# Set to true to enable this Grafana instance act as an external snapshot server and allow unauthenticated requests for
# creating and deleting snapshots.
;public_mode = false
#################################### Dashboards ##################
[dashboards]
# Number dashboard versions to keep (per dashboard). Default: 20, Minimum: 1
;versions_to_keep = 20
# Minimum dashboard refresh interval. When set, this will restrict users to set the refresh interval of a dashboard lower than given interval. Per default this is 5 seconds.
# The interval string is a possibly signed sequence of decimal numbers, followed by a unit suffix (ms, s, m, h, d), e.g. 30s or 1m.
;min_refresh_interval = 5s
# Path to the default home dashboard. If this value is empty, then Grafana uses StaticRootPath + "dashboards/home.json"
;default_home_dashboard_path =
################################### Data sources #########################
[datasources]
# Upper limit of data sources that Grafana will return. This limit is a temporary configuration and it will be deprecated when pagination will be introduced on the list data sources API.
;datasource_limit = 5000
# Number of queries to be executed concurrently. Only for the datasource supports concurrency.
# For now only Loki and InfluxDB (with influxql) are supporting concurrency behind the feature flags.
# Check datasource documentations for enabling concurrency.
;concurrent_query_count = 10
# Default behavior for the "Manage alerts via Alerting UI" toggle when configuring a data source.
# It only works if the data source's `jsonData.manageAlerts` prop does not contain a previously configured value.
;default_manage_alerts_ui_toggle = true
# Default behavior for the "Allow as recording rules target" toggle when configuring a data source.
# It only works if the data source's `jsonData.allowAsRecordingRulesTarget` prop does not contain a previously configured value.
;default_allow_recording_rules_target_alerts_ui_toggle = true
################################### SQL Data Sources #####################
[sql_datasources]
# Default maximum number of open connections maintained in the connection pool
# when connecting to SQL based data sources
;max_open_conns_default = 100
# Default maximum number of idle connections maintained in the connection pool
;max_idle_conns_default = 100
# Default maximum connection lifetime used when connecting
# to SQL based data sources.
;max_conn_lifetime_default = 14400
#################################### Users ###############################
[users]
# disable user signup / registration
;allow_sign_up = true
# Allow non admin users to create organizations
;allow_org_create = true
# Set to true to automatically assign new users to the default organization (id 1)
;auto_assign_org = true
# Set this value to automatically add new users to the provided organization (if auto_assign_org above is set to true)
;auto_assign_org_id = 1
# Default role new users will be automatically assigned
;auto_assign_org_role = Viewer
# Require email validation before sign up completes
;verify_email_enabled = false
# Redirect to default OrgId after login
;login_default_org_id =
# Background text for the user field on the login page
;login_hint = email or username
;password_hint = password
# Default UI theme ("dark", "light" or "system")
;default_theme = dark
# Default UI language (supported IETF language tag, such as en-US)
;default_language = en-US
# Path to a custom home page. Users are only redirected to this if the default home dashboard is used. It should match a frontend route and contain a leading slash.
;home_page =
# External user management, these options affect the organization users view
;external_manage_link_url =
;external_manage_link_name =
;external_manage_info =
# Deprecated: Assign your viewers to editors.
# Viewers can edit/inspect dashboard settings in the browser. But not save the dashboard.
;viewers_can_edit = false
# Deprecated: Assign your editors to admins.
# Editors can administrate dashboard, folders and teams they create
;editors_can_admin = false
# The duration in time a user invitation remains valid before expiring. This setting should be expressed as a duration. Examples: 6h (hours), 2d (days), 1w (week). Default is 24h (24 hours). The minimum supported duration is 15m (15 minutes).
;user_invite_max_lifetime_duration = 24h
# The duration in time a verification email, used to update the email address of a user, remains valid before expiring. This setting should be expressed as a duration. Examples: 6h (hours), 2d (days), 1w (week). Default is 1h (1 hour).
;verification_email_max_lifetime_duration = 1h
# Frequency of updating a user's last seen time. The minimum supported duration is 5m (5 minutes). The maximum supported duration is 1h (1 hour).
;last_seen_update_interval = 15m
# Enter a comma-separated list of users login to hide them in the Grafana UI. These users are shown to Grafana admins and themselves.
; hidden_users =
[secretscan]
# Enable secretscan feature
;enabled = false
# Interval to check for token leaks
;interval = 5m
# base URL of the grafana token leak check service
;base_url = https://secret-scanning.grafana.net
# URL to send outgoing webhooks to in case of detection
;oncall_url =
# Whether to revoke the token if a leak is detected or just send a notification
;revoke = true
[service_accounts]
# Service account maximum expiration date in days.
# When set, Grafana will not allow the creation of tokens with expiry greater than this setting.
; token_expiration_day_limit =
[auth]
# Login cookie name
login_cookie_name =__prusa-grafana_session
# Disable usage of Grafana build-in login solution.
;disable_login = false
# The maximum lifetime (duration) an authenticated user can be inactive before being required to login at next visit. Default is 7 days (7d). This setting should be expressed as a duration, e.g. 5m (minutes), 6h (hours), 10d (days), 2w (weeks), 1M (month). The lifetime resets at each successful token rotation.
;login_maximum_inactive_lifetime_duration =
# The maximum lifetime (duration) an authenticated user can be logged in since login time before being required to login. Default is 30 days (30d). This setting should be expressed as a duration, e.g. 5m (minutes), 6h (hours), 10d (days), 2w (weeks), 1M (month).
;login_maximum_lifetime_duration =
# How often should auth tokens be rotated for authenticated users when being active. The default is each 10 minutes.
;token_rotation_interval_minutes = 10
# Set to true to disable (hide) the login form, useful if you use OAuth, defaults to false
;disable_login_form = false
# Set to true to disable the sign out link in the side menu. Useful if you use auth.proxy or auth.jwt, defaults to false
;disable_signout_menu = false
# URL to redirect the user to after sign out
;signout_redirect_url =
# Set to true to attempt login with OAuth automatically, skipping the login screen.
# This setting is ignored if multiple OAuth providers are configured.
# Deprecated, use auto_login option for specific provider instead.
;oauth_auto_login = false
# Sets a custom oAuth error message. This is useful if you need to point the users to a specific location for support.
;oauth_login_error_message = oauth.login.error
# OAuth state max age cookie duration in seconds. Defaults to 600 seconds.
;oauth_state_cookie_max_age = 600
# Minimum wait time in milliseconds for the server lock retry mechanism.
# The server lock retry mechanism is used to prevent multiple Grafana instances from
# simultaneously refreshing OAuth tokens. This mechanism waits at least this amount
# of time before retrying to acquire the server lock. There are 5 retries in total.
# The wait time between retries is calculated as random(n, n + 500)
; oauth_refresh_token_server_lock_min_wait_ms = 1000
# limit of api_key seconds to live before expiration
;api_key_max_seconds_to_live = -1
# Set to true to enable SigV4 authentication option for HTTP-based datasources.
;sigv4_auth_enabled = false
# Set to true to enable verbose logging of SigV4 request signing
;sigv4_verbose_logging = false
# Set to true to enable Azure authentication option for HTTP-based datasources.
;azure_auth_enabled = false
# Use email lookup in addition to the unique ID provided by the IdP
;oauth_allow_insecure_email_lookup = false
# Set to true to include id of identity as a response header
;id_response_header_enabled = false
# Prefix used for the id response header, X-Grafana-Identity-Id
;id_response_header_prefix = X-Grafana
# List of identity namespaces to add id response headers for, separated by space.
# Available namespaces are user, api-key and service-account.
# The header value will encode the namespace ("user:<id>", "api-key:<id>", "service-account:<id>")
;id_response_header_namespaces = user api-key service-account
# Enables the use of managed service accounts for plugin authentication
# This feature currently **only supports single-organization deployments**
; managed_service_accounts_enabled = false
#################################### Anonymous Auth ######################
[auth.anonymous]
# enable anonymous access
;enabled = false
# specify organization name that should be used for unauthenticated users
;org_name = Main Org.
# specify role for unauthenticated users
;org_role = Viewer
# mask the Grafana version number for unauthenticated users
hide_version = true
# number of devices in total
;device_limit =
#################################### GitHub Auth ##########################
[auth.github]
;name = GitHub
;icon = github
;enabled = false
;auto_login = false
;client_id = some_id
;client_secret = some_secret
;scopes = user:email,read:org
;auth_url = https://github.com/login/oauth/authorize
;token_url = https://github.com/login/oauth/access_token
;api_url = https://api.github.com/user
;allowed_domains =
;team_ids =
;allowed_organizations =
;role_attribute_path =
;role_attribute_strict = false
;org_mapping =
;allow_assign_grafana_admin = false
;skip_org_role_sync = false
;tls_skip_verify_insecure = false
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
# GitHub OAuth apps does not provide refresh tokens and the access tokens never expires.
;use_refresh_token = false
#################################### GitLab Auth #########################
[auth.gitlab]
;name = GitLab
;icon = gitlab
;enabled = false
;auto_login = false
;scopes = openid email profile
;auth_url = https://gitlab.com/oauth/authorize
;token_url = https://gitlab.com/oauth/token
;api_url = https://gitlab.com/api/v4
;allowed_domains =
;allowed_groups =
;org_mapping =
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
;use_pkce = true
;use_refresh_token = true
#################################### Google Auth ##########################
[auth.google]
;name = Google
;icon = google
;enabled = false
;auto_login = false
;client_id = some_client_id
;client_secret = some_client_secret
;auth_url = https://accounts.google.com/o/oauth2/v2/auth
;token_url = https://oauth2.googleapis.com/token
;api_url = https://openidconnect.googleapis.com/v1/userinfo
;allowed_domains =
;validate_hd =
;hosted_domain =
;allowed_groups =
;org_mapping =
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
;use_pkce = true
#################################### Grafana.com Auth ####################
[auth.grafana_com]
;name = Grafana.com
;icon = grafana
;enabled = false
;auto_login = false
#################################### Azure AD OAuth #######################
[auth.azuread]
;name = Microsoft
;icon = microsoft
;enabled = false
;auto_login = false
;client_authentication =
;managed_identity_client_id =
;federated_credential_audience =
;workload_identity_token_file =
;auth_url = https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/authorize
;token_url = https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/token
;allowed_domains =
;allowed_groups =
;org_mapping =
;use_pkce = true
# prevent synchronizing users organization roles
#################################### Okta OAuth #######################
[auth.okta]
;name = Okta
;enabled = false
;auto_login = false
;scopes = openid profile email groups
;auth_url = https://<tenant-id>.okta.com/oauth2/v1/authorize
;token_url = https://<tenant-id>.okta.com/oauth2/v1/token
;api_url = https://<tenant-id>.okta.com/oauth2/v1/userinfo
;allowed_domains =
;allowed_groups =
; org_attribute_path =
; org_mapping =
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
;use_pkce = true
#################################### Generic OAuth ##########################
[auth.generic_oauth]
;name = OAuth
;icon = signin
;enabled = false
;auto_login = false
;empty_scopes = false
;email_attribute_name = email:primary
;email_attribute_path =
;login_attribute_path =
;name_attribute_path =
;groups_attribute_path =
;id_token_attribute_name =
;team_ids_attribute_path
;auth_url = https://foo.bar/login/oauth/authorize
;token_url = https://foo.bar/login/oauth/access_token
;api_url = https://foo.bar/user
;teams_url =
;allowed_domains =
;team_ids =
;org_attribute_path =
;org_mapping =
;team_ids_attribute_path =
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
;use_pkce = false
;auth_style =
#################################### Basic Auth ##########################
[auth.basic]
;enabled = true
;password_policy = false
#################################### Auth Proxy ##########################
[auth.proxy]
;enabled = false
;header_name = X-WEBAUTH-USER
;header_property = username
;auto_sign_up = true
;sync_ttl = 60
;whitelist = 192.168.1.1, 192.168.2.1
;headers = Email:X-User-Email, Name:X-User-Name
# Non-ASCII strings in header values are encoded using quoted-printable encoding
;headers_encoded = false
# Read the auth proxy docs for details on what the setting below enables
;enable_login_token = false
#################################### Auth JWT ##########################
[auth.jwt]
;enabled = true
;header_name = X-JWT-Assertion
;email_claim = sub
;username_claim = sub
;email_attribute_path = jmespath.email
;username_attribute_path = jmespath.username
;jwk_set_url = https://foo.bar/.well-known/jwks.json
;jwk_set_file = /path/to/jwks.json
;cache_ttl = 60m
;expect_claims = {"aud": ["foo", "bar"]}
;key_file = /path/to/key/file
# Use in conjunction with key_file in case the JWT token's header specifies a key ID in "kid" field
;key_id = some-key-id
;org_mapping =
;auto_sign_up = false
;url_login = false
#################################### Auth LDAP ##########################
[auth.ldap]
;enabled = false
;config_file = /etc/grafana/ldap.toml
# prevent synchronizing ldap users organization roles
# LDAP background sync (Enterprise only)
# At 1 am every day
;sync_cron = "0 1 * * *"
;active_sync_enabled = true
#################################### AWS ###########################
[aws]
# Enter a comma-separated list of allowed AWS authentication providers.
# Options are: default (AWS SDK Default), keys (Access && secret key), credentials (Credentials field), ec2_iam_role (EC2 IAM Role)
; allowed_auth_providers = default,keys,credentials
# Allow AWS users to assume a role using temporary security credentials.
# If true, assume role will be enabled for all AWS authentication providers that are specified in aws_auth_providers
; assume_role_enabled = true
# Specify max no of pages to be returned by the ListMetricPages API
; list_metrics_page_limit = 500
# Experimental, for use in Grafana Cloud only. Please do not set.
; external_id =
# Sets the expiry duration of an assumed role.
# This setting should be expressed as a duration. Examples: 6h (hours), 10d (days), 2w (weeks), 1M (month).
; session_duration = "15m"
# Set the plugins that will receive AWS settings for each request (via plugin context)
# By default this will include all Grafana Labs owned AWS plugins, or those that make use of AWS settings (ElasticSearch, Prometheus).
; forward_settings_to_plugins = cloudwatch, grafana-athena-datasource, grafana-redshift-datasource, grafana-x-ray-datasource, grafana-timestream-datasource, grafana-iot-sitewise-datasource, grafana-iot-twinmaker-app, grafana-opensearch-datasource, aws-datasource-provisioner, elasticsearch, prometheus
#################################### Azure ###############################
[azure]
# Azure cloud environment where Grafana is hosted
# Possible values are AzureCloud, AzureChinaCloud, AzureUSGovernment and AzureGermanCloud
# Default value is AzureCloud (i.e. public cloud)
;cloud = AzureCloud
# A customized list of Azure cloud settings and properties, used by data sources which need this information when run in non-standard azure environments
# When specified, this list will replace the default cloud list of AzureCloud, AzureChinaCloud, AzureUSGovernment and AzureGermanCloud
;clouds_config = `[
;			"name":"CustomCloud1",
;			"displayName":"Custom Cloud 1",
;			"aadAuthority":"https://login.cloud1.contoso.com/",
;			"properties":{
;				"azureDataExplorerSuffix": ".kusto.windows.cloud1.contoso.com",
;				"logAnalytics":            "https://api.loganalytics.cloud1.contoso.com",
;				"portal":                  "https://portal.azure.cloud1.contoso.com",
;				"prometheusResourceId":    "https://prometheus.monitor.azure.cloud1.contoso.com",
;				"resourceManager":         "https://management.azure.cloud1.contoso.com"
# Specifies whether Grafana hosted in Azure service with Managed Identity configured (e.g. Azure Virtual Machines instance)
# If enabled, the managed identity can be used for authentication of Grafana in Azure services
# Disabled by default, needs to be explicitly enabled
;managed_identity_enabled = false
# Client ID to use for user-assigned managed identity
# Should be set for user-assigned identity and should be empty for system-assigned identity
# Specifies whether Azure AD Workload Identity authentication should be enabled in datasources that support it
# For more documentation on Azure AD Workload Identity, review this documentation:
# https://azure.github.io/azure-workload-identity/docs/
;workload_identity_enabled = false
# Tenant ID of the Azure AD Workload Identity
# Allows to override default tenant ID of the Azure AD identity associated with the Kubernetes service account
;workload_identity_tenant_id =
# Client ID of the Azure AD Workload Identity
# Allows to override default client ID of the Azure AD identity associated with the Kubernetes service account
;workload_identity_client_id =
# Custom path to token file for the Azure AD Workload Identity
# Allows to set a custom path to the projected service account token file
# Specifies whether user identity authentication (on behalf of currently signed-in user) should be enabled in datasources
# that support it (requires AAD authentication)
;user_identity_enabled = false
# Specifies whether user identity authentication fallback credentials should be enabled in data sources
# Enabling this allows data source creators to provide fallback credentials for backend initiated requests
# e.g. alerting, recorded queries etc.
# Enabled by default, needs to be explicitly disabled
# Will not have any effect if user identity is disabled above
;user_identity_fallback_credentials_enabled = true
Grafana logs are too long to paste to the post, and the forum won’t allow me to attach them as a file. But I’m comfortable sharing them with anyone who asks.
Yes, before the reboot, I was getting red “internal server error” warnings in the Grafana WebUI, which I access through a reverse proxy. I’m still unable to log into my instance even without the reverse proxy.
Yes, I was following the “instructions” under Node Exporter’s dashboard Grafana listing.
Thank you for any help. I’m still pretty new to using Grafana, so any help is greatly appreciated.
Welcome to forum @atmosphericignition
You have a lot of pertinent and important stuff commented out with ; Can you remove everything you have commented out?
Done:
[paths]
[server]
[environment]
[database]
[remote_cache]
[dataproxy]
[analytics]
[security]
[snapshots]
[dashboards]
[datasources]
[sql_datasources]
[users]
[secretscan]
[service_accounts]
[auth]
[auth.anonymous]
hide_version = true
[auth.github]
[auth.gitlab]
[auth.google]
[auth.grafana_com]
[auth.azuread]
[auth.okta]
[auth.basic]
[auth.proxy]
[auth.jwt]
[auth.ldap]
[aws]
[azure]
[rbac]
[smtp]
[smtp.static_headers]
[emails]
[log]
[log.console]
[log.file]
[log.syslog]
[log.frontend]
[quota]
[unified_alerting]
[unified_alerting.screenshots]
[unified_alerting.reserved_labels]
disabled_labels =
[unified_alerting.state_history]
[unified_alerting.state_history.external_labels]
[unified_alerting.state_history.annotations]
max_age =
max_annotations_to_keep =
[unified_alerting.prometheus_conversion]
rule_query_offset = 1m
[recording_rules]
enabled = true
timeout = 30s
default_datasource_uid =
[recording_rules.custom_headers]
[annotations]
[annotations.dashboard]
[annotations.api]
[explore]
[help]
[profile]
[news]
[query]
[query_history]
[short_links]
[metrics]
basic_auth_username =
basic_auth_password =
[metrics.environment_info]
[metrics.graphite]
[grafana_com]
[tracing.jaeger]
[tracing.opentelemetry]
[tracing.opentelemetry.jaeger]
[tracing.opentelemetry.otlp]
[external_image_storage]
[external_image_storage.s3]
[external_image_storage.webdav]
[external_image_storage.gcs]
[external_image_storage.azure_blob]
[external_image_storage.local]
[rendering]
[panels]
[plugins]
[live]
[plugin.grafana-image-renderer]
[enterprise]
[feature_toggles]
[date_formats]
[time_picker]
[expressions]
[geomap]
[support_bundles]
[navigation.app_sections]
[navigation.app_standalone_pages]
[secure_socks_datasource_proxy]
[feature_management]
[public_dashboards]
[cloud_migration]
[secrets_manager]
[frontend_dev]
