Hi All,
I am trying to use the ssl certificates for changing the grafana to https. I have added the ssl certificates in the /etc/ssl/httpscertificate path and the grafana file is located in the /etc/grafana path.
Below Iam sharing the conf file
##################### Grafana Configuration Example #####################
Everything has defaults so you only need to uncomment things you want to
change
possible values : production, development
;app_mode = production
instance name, defaults to HOSTNAME environment variable value or hostname if HOSTNAME var is empty
;instance_name = ${HOSTNAME}
#################################### Paths ####################################
[paths]
Path to where grafana can store temp files, sessions, and the sqlite3 db (if that is used)
;data = /var/lib/grafana
Temporary files in data directory older than given duration will be removed
;temp_data_lifetime = 24h
Directory where grafana can store logs
;logs = /var/log/grafana
Directory where grafana will automatically scan and look for plugins
;plugins = /var/lib/grafana/plugins
folder that contains provisioning config files that grafana will apply on startup and while running.
;provisioning = conf/provisioning
#################################### Server ####################################
[server]
Protocol (http, https, h2, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
;http_addr =
The http port to use
;http_port = 3000
The public facing domain name used to access grafana from a browser
;domain = localhost
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
;enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://10.130.74.68:3000
Serve Grafana from subpath specified in root_url setting. By default it is set to false for compatibility reasons.
;serve_from_sub_path = false
Log web requests
;router_logging = false
the path relative working path
;static_root_path = public
enable gzip
;enable_gzip = false
https certs & key file
cert_file = /etc/ssl/httpscertificate/graf-grafana.lb-ibmmc-geico.net.crt
cert_key = /etc/ssl/httpscertificate/graf-grafana.lb-ibmmc-geico.net.key
Unix socket path
;socket =
#################################### Database ####################################
[database]
You can configure the database connection by specifying type, host, name, user and password
as separate properties or as on string using the url properties.
Either “mysql”, “postgres” or “sqlite3”, it’s your choice
;type = sqlite3
;host = 127.0.0.1:3306
;name = grafana
;user = root
If the password contains # or ; you have to wrap it with triple quotes. Ex “”“#password;”“”
;password =
Use either URL or the previous fields to configure the database
Example: mysql://user:secret@host:port/database
;url =
For “postgres” only, either “disable”, “require” or “verify-full”
;ssl_mode = disable
;ca_cert_path =
;client_key_path =
;client_cert_path =
;server_cert_name =
For “sqlite3” only, path relative to data_path setting
;path = grafana.db
Max idle conn setting default is 2
;max_idle_conn = 2
Max conn setting default is 0 (mean not set)
;max_open_conn =
Connection Max Lifetime default is 14400 (means 14400 seconds or 4 hours)
;conn_max_lifetime = 14400
Set to true to log the sql calls and execution times.
;log_queries =
For “sqlite3” only. cache mode setting used for connecting to the database. (private, shared)
;cache_mode = private
#################################### Cache server #############################
[remote_cache]
Either “redis”, “memcached” or “database” default is “database”
;type = database
cache connectionstring options
database: will use Grafana primary database.
redis: config like redis server e.g. addr=127.0.0.1:6379,pool_size=100,db=0,ssl=false. Only addr is required. ssl may be ‘true’, ‘false’, or ‘insecure’.
memcache: 127.0.0.1:11211
;connstr =
#################################### Data proxy ###########################
[dataproxy]
This enables data proxy logging, default is false
;logging = false
How long the data proxy should wait before timing out default is 30 (seconds)
;timeout = 30
If enabled and user is not anonymous, data proxy will add X-Grafana-User header with username into the request, default is false.
;send_user_header = false
#################################### Analytics ####################################
[analytics]
Server reporting, sends usage counters to stats.grafana.org every 24 hours.
No ip addresses are being tracked, only simple counters to track
running instances, dashboard and error counts. It is very helpful to us.
Change this option to false to disable reporting.
;reporting_enabled = true
Set to false to disable all checks to https://grafana.net
for new vesions (grafana itself and plugins), check is used
in some UI views to notify that grafana or plugin update exists
This option does not cause any auto updates, nor send any information
only a GET request to http://grafana.com to get latest versions
;check_for_updates = true
Google Analytics universal tracking code, only enabled if you specify an id here
;google_analytics_ua_id =
Google Tag Manager ID, only enabled if you specify an id here
;google_tag_manager_id =
#################################### Security ####################################
[security]
disable creation of admin user on first start of grafana
;disable_initial_admin_creation = false
default admin user, created on startup
;admin_user = admin
default admin password, can be changed before first start of grafana, or in profile settings
;admin_password = admin
used for signing
;secret_key = SW2YcwTIb9zpOOhoPsMm
disable gravatar profile images
;disable_gravatar = false
data source proxy whitelist (ip_or_domain:port separated by spaces)
;data_source_proxy_whitelist =
disable protection against brute force login attempts
;disable_brute_force_login_protection = false
set to true if you host Grafana behind HTTPS. default is false.
;cookie_secure = false
set cookie SameSite attribute. defaults to lax. can be set to “lax”, “strict”, “none” and “disabled”
;cookie_samesite = lax
