Failed to look up user based on cookie issue
    7.5.5-1 (Amazon Linux 2)
    We are setting up HA cluster for Grafana
    We have Load Balancer in place and behind two grafana instances running with Mysql replication as master-master. We have configured grafana to restore dashboards, user data, session in Mysql backend database.
  • What happened?
    When we are logging in immediately we are logging out with an error ‘Unauthorized’ in browser whereas in grafana.log we are getting an error , "lvl=eror msg=“Failed to look up user based on cookie” logger=context error=“user token not found”
    We should not logged.
    /etc/grafana/grafana.ini
[paths]
[server]
protocol = http
root_url = http://grafana.staged-by-discourse.com
[database]
type = mysql
host = 127.0.0.1:3306
name = XXXXXXX
user = XXXXXX
password = xxxxxx
log_queries = true
[session]
provider = mysql
provider_config = XXXXX:XXXXXXXXX@tcp(127.0.0.1:3306)/XXXXX
[dataproxy]
[analytics]
[security]
[snapshots]
[users]
login_hint = Enter LDAP User ID
[auth]
[auth.anonymous]
[auth.google]
[auth.generic_oauth]
[auth.grafana_com]
[auth.basic]
[auth.ldap]
enabled = true
config_file = /etc/grafana/ldap.toml
allow_sign_up = true
[smtp]
enabled = true
host = localhost:25
from_address = admin@grafana.localhost
from_name = Grafana
ehlo_identity = dashboard.example.com
[emails]
[log]
level = error
[log.console]
[log.file]
[log.syslog]
[alerting]
[metrics]
[metrics.graphite]
[tracing.jaeger]
[grafana_com]
;url = https://grafana.com
[external_image_storage]
[external_image_storage.s3]
[external_image_storage.webdav]
[external_image_storage.azure_blob]
[external_image_storage.local]
[panels]
disable_sanitize_html = true
[log]
filters = “ldap:debug”
[[servers]]
host = “ldap.XXXXXXXX.com
port = XXX
use_ssl = true
start_tls = false
ssl_skip_verify = false
root_ca_cert = “/etc/cert/XXXXXXXX”
bind_dn = “CN=XXXXXXXX,OU=Service Accounts,OU=XXXXX,OU=XXXXXX,OU=Servers and Services,DC=XXXXXX,DC=XXXXXX”
bind_password = ‘XXXXXXXX’
search_filter = “(sAMAccountName=%s)”
search_base_dns = [“DC=XXXXXXX,DC=com”]
[servers.attributes]
name = “givenName”
surname = “sn”
username = “sAMAccountName”
member_of = “memberOf”
email = “email”
[[servers.group_mappings]]
group_dn = “CN=XXXXXXX,OU=XXXXXXX,OU=XXXXXX,DC=XXXXXXX,DC=com”
org_role = “Admin”
group_dn = “CN=XXXXXXX,OU=XXXXXXXX,OU=XXXXXXXX,DC=XXXXXXX,DC=com”
org_role = “Editor”
group_dn = “CN=XXXXXX,OU=XXXXXXX,OU=XXXXX,OU=XXXXXX,DC=XXXXXX,DC=com”
org_role = “Viewer”
After login (with Ldap user ) we get an error “unauthorised” and logged out. In grafana error logs getting following error
    Yes we tried all possible solution posted on different grafana community and other links but still having the same issue.
Hello All Community members,
Kindly help to resolve above issue.
Thanks in Advance.
