v9.2.0 on RHEL 7.9 -
Run Grafana under subpath /grafana so it can be exposed via a reverse proxy -
Set the following in grafana.ini:
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana
serve_from_sub_path = true -
What happened?
Everything works fine except I am no longer able to login as a specific user. All logins seem to be interpreted as anonymous. -
Keep the behaviour unchanged, i.e., anonymous logins work and admin access works. -
See above -
No real error. After grafana.ini modification, I get the following in the log file:
logger=context t=2023-12-12T10:23:27.911692329+01:00 level=warn msg=“Failed to look up user based on cookie” error=“user token not found”
logger=http.server t=2023-12-12T10:23:27.927703349+01:00 level=info msg=“Successful Login” User=michaje
logger=context t=2023-12-12T10:23:27.95020427+01:00 level=warn msg=“Failed to look up user based on cookie” error=“user token not found”
logger=context t=2023-12-12T10:23:28.128200937+01:00 level=warn msg=“Failed to look up user based on cookie” error=“user token not found” -
Shame on me. Clearing the browser cache did the trick.
