What Grafana version and what operating system are you using? 8.1
What are you trying to achieve? login to the HA grafana
How are you trying to achieve it? using nginx proxy to login to the grafana servers
What happened? the login screen appears but logs out after entering the credentials
What did you expect to happen? the login page should go through
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. UI says logged in and in the logs i could see the error:
t=2021-08-17T07:57:07-0400 lvl=eror msg=“Failed to look up user based on cookie” logger=context error=“user token not found”
- Did you follow any online instructions? If so, what is the URL? yes i set cookie to disable and set the below parameters
cookie_samesite = disabled
login_maximum_inactive_lifetime_duration = 6M
login_maximum_inactive_lifetime_days = 90d
login_maximum_lifetime_duration = 90d
token_rotation_interval_minutes = 120
