Failed to add Infinity Plugin in grafana admin
  1. In Linux VM, Copied Grafana folder - grafana-10.0.3.linux-amd64
    and added Infinity plugin
  2. Under Datasources - when click on save & test Infinity Datasource
a warning displayed as Plugin unavailable - attached file for reference.
Try to set Network - Skip TLS Verify and check if it helps:
Thanks for the advice… after enabling “Skip TLS Verify” - still didnt work…
Any more suggestions please
why are you copying things and how did you add the infinity plugin?
