Grafana 13.0.1: datasource Infinity gone
  • 13.01.1 on windows
Hello all,
after the update to Grafana 13 on Windows thew infinity-datasourc eis gone.
And I don 't find it in the plugins-page …
Has anyone an idea?
Thanks and regards
Jürgen
I gues, that’s the problem:
You can also try to download zip file and unzip to install in plugins directory
Hello @jo49 you can add this via grafana plugin ui , if you don’t see here please restart the grafana also have feature to downgrad you plugin compatable version.
Thanks for your hnts. Solved it like yosiasz mentioned**.**
But why did it disapear, also from the Plugin-List inside Grafana?
