What Grafana version and what operating system are you using? Grafana v11.6.0
What are you trying to achieve? Trying to connect SWQL Studio to Grafana using the Infinity datasource
How are you trying to achieve it? I am trying to do this using a vetted username and password for SWQL Studio requesting Json data
What happened? I receive a no response error and a tls:failed to parse certificate from server: x509: negative serial number error
What did you expect to happen? I expected the test to go through without issue.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. error getting response from url https://MY SERVER NAME:17774/SolarWinds/Orion/v3/Json/Query?query=SELECT+TOP+1+Uri+FROM+Orion.Pollers. no response received. Error: Get “https://MY SERVER NAME:17774/SolarWinds/InformationService/v3/Json/Queryhttps://usilg01-app589:17774/SolarWinds/Orion/v3/Json/Query?query=SELECT+TOP+1+Uri+FROM+Orion.Pollers”: tls: failed to parse certificate from server: x509: negative serial number
Did you follow any online instructions? If so, what is the URL? Yes I did. Connecting to the SWIS API with Grafana - DevOps Forum - DevOps Discourse - THWACK
There is a wonderful article about this SolarWinds API Example · grafana/grafana-infinity-datasource · Discussion #1137 · GitHub
You can post any queries related to SolarWinds + Infinity there. Hope that helps.
That post is very helpful, thanks for writing it. It has helped me get this far.
I will check on my version and see if the cert issue is within SolarWinds for me as well. Thanks for the help!
